Front sprocket
blakebammeyers
Illinois
I have a predator 212 with a knockoff comet TAV2-30 series torque converter. The axle on my go kart has a 428 chain rear sprocket, and my torque converter only came with a #35 and #41 chain front sprocket. I have a brand new heavy duty 428 chain that fits my rear sprocket, but not my front sprocket obviously. The driveshaft on my torque converter is 5/8", and I'm pretty sure 16mm is pretty close to it. I need to find a 428 chain front sprocket with a 5/8" or 16mm bore, but I've looked on Google and eBay but still nothing. I can't find it anywhere. The rear sprocket on my axle definitely is not going anywhere. It's rusted to the axle which I can't afford to replace. Is there a front sprocket with a similar chain size I could use that has a 5/8" or 16mm bore? I appreciate the help.
I think 428 is similar to #41. 428 chain should work on a #41 sprocket I THINK.
Read this thread...
http://www.diygokarts.com/vb/showthread.php?t=10135
Roller width is a little wider on the 428 (5/16" vs 1/4")
I haven't seen a 428 C-Type sprocket yet...
And frankly, since that's a fairly common gy6 size I have the strong feeling,
that you converted a gy6 kart to a industrial engine kart and that just won't work at all...
The rear sprocket on most gy6 powered karts I've seen is ridiculously small (the engine is geared down internally by a good amount)
so you have maybe a 48T sprocket.. and that will not work anyways!
Buy a #40 chain swap out the sprocket to something like 70 Teeth #40 (yes.... I think you'd need that many teeth) and then use the 10T #41 the TC came with.
And...before you say it...it doesn't really matter that you can get the old sprocket off!
You just don't have a choice...you could possibly just scab the new sprocket onto the old one ....(think about it!)....the alignment would still be near perfect...the smaller sprocket would act as a stabilizer for the new one...
