Sounds like a plan, Bob....ESPECIALLY....when you described the sucking sound after stopping the engine. (So the WD could be very telling) ...(sounding more and more like a lean condition.....BUT....typically...tuning a carb.....you richen up the idle mixture until it almost dies....then back off a little....then go from idle to full throttle and continue to lean out until it no longer stumbles during that....IDK!
I know I hear a sucking sound after a FreeRunner vid....WAIT....that's DURING!
Started it up. Once warmed up to a steady 1850 idle, I hit the head/adapter and adapter/carb seals with WD-40. After a few seconds, it died. Started right back up, tried it again, same results. Tried a third time, same results.
I was expecting nothing or an increase in RPMs. I was't expecting to kill it.
Regardless, that shows a leak....just saying...try it with carb or brake cleaner...even so....spraying carb cleaner in the carb can cause it to die?????
Jrgunn5150
Rudderless
I've never used WD40, I'm not sure what effect it has. Starting fluid causes an idle increase, propane also, along with some smoke, which is really helpful.
The two engine go kart, was awesome for a kid. But it was way too long, and, I don't believe two engines are better than one big one.
rk970
Coupeville, WA
In regards to valve clearance on mechanical flat tappet cams..
The cam has ground in clearance ramps, it comes off the base circle and transitions into the flank. They are meant to take up clearance gradually so as not to "shock" the lifter, push rod, rocker ect... If a cam grinder/manufacture has a valve clearance spec..USE IT!..
Here is a good example with descriptions of the various aspects of mechanical cams
http://www.webcamshafts.com/index_blank.html?pages/cam_glossary.html
And yes WD40 does burn and will lower/raise idle through a vacuum leak. (If idle mix is adjusted for the vacuum leak introducing WD40 will richen the mix and lower the idle speed)
rk..
Dealer busts. Everybody wins!
Isn't learning fun?
Thanks!
---------- Post added at 07:48 PM ---------- Previous post was at 07:40 PM ----------
By the time we are done here. We will have adjusted and played with everything.
The whole process has been extremely educational so far.
If nothing else, the free text book is fantastic! It's the lab fees that are expensive!
I feel like Oprah!!!
And you get a gasket! And you get a gasket! And you get a gasket.... Look under your seats....
GASKETS FOR EVERYBODY!!!!
Also got the 0.027" Head Gasket.
Only thing I'll add to this is the adapter he's using puts the carb at a 15° tilt. Maybe something or maybe nothing, but I do think the volume of fuel in the bowl is diminished.
Bob58o I wouldn't look into adjusting the float as much as I'd look into the flat mount kit from NR racing if you think fuel level is an issue. http://www.nrracing.com/product-p/nr-cc390c.htm
Researching a thread, diff forum, similar build.
11-23-2013, 07:20 AM #50
vwfan79
"Everything looks good with your build but I have one question, and maybe its answered and I just missed it, your using a 390 carb with arc adapter is your motor plate on an angle? The reason I ask is that unless they have a new adapter the one I got is ment for kart racing where the motor is at 15 degrees. On a flat surface it drowns the idle circuit and the motor doesn't want to idle good if at all. On a flat surface my motor will only idle on half choke, but once I get going it screams with the 390 carb. I have a similar build as you and will be seen in a future bike build, my specs are hemi block .010 head gasket Honda 14cc head all port matched ss valves with locks and retainers 26# springs 1.3 rockers black mamba cam arc rod 390 carb with air filter rlv header, I feel like I might have missed something but you get the idea. Anyways great thread love all the detail."
---------- Post added at 02:41 AM ---------- Previous post was at 02:25 AM ----------
http://www.nrracing.com/product-p/nr-cc390b.htm
This is the two piece carb adapter that NR sells.
Designed to mount GX390 Type Carbs to GX200, 6.5s, and 212 Predators.
2 pc Design can be used on both flat and 15 degree mounts.
Typically requires a 108 Main Jet for std bore Gas GX390 carbs and 110 for Gas Bored Carbs. Methanol carbs will need a 150 to 160 Main or larger.
Pulse Fitting can be installed for operating fuel pumps, otherwise plug can be used to seal opening. NOTE: PULSE FITTING FACES UP Note: On some Long Duration (radical) cams, the intake vacuum signal is too weak to operate the fuel pump, esp when using methanol. In this case, you will need to pulse from the valve cover or block.
Instructions: Mount the 15 degree adapter (the thicker one) to Engine. Mount Flat Plate adapter to the 15 degree adapter. Use a small amount of gasket sealer between the two. Install the carb studs in appropriate holes, mount carb using enclosed gasket, and go racing.
---------- Post added at 02:44 AM ---------- Previous post was at 02:41 AM ----------
Long style gx390 to 200 manifold
http://www.nrracing.com/product-p/qmnrr-12.htm
Intake Manifold, GX390 Carb to GX200. Does not require insulator plate. Includes Pulse fitting for Fuel pump.
Typically requires a 100 Main Jet for std bore Gas GX390 carbs and 102 or 105 for Gas Bored Carbs. Methanol carbs will need a 150 to 160 Main
---------- Post added at 02:51 AM ---------- Previous post was at 02:44 AM ----------
"I talked to russ about the safe issue regarding the arc adapter. i told him the air bleed on the back of the 390 carb was un able to vent with just the adapter.... you can do two things... One is run a insulator...and you still at a 15 deg angle, or you can jb weld the back of the carb, and drill the air bleed on top/side of carb with a small nipple to vent...this will allow no insulator just gaskets and give the true stock appearing look. If you get nr racings 390 to gx200 adaptor it all ready had the insulators vent areas built in...and will sit at the angle you need... if you go this route the carb is nowhere near as aggressive as the short arc adapter..it feel like a 22mm at best... the first way at the 15 angle did idle and surge...but as soon as you got full throttle it was like warp speed...just food for thought."
cavfire
auburn, georgia
Some interesting comments from vwfan79. I've got the ARC adapter, and I wondered if the reduced bowl vent played into my low fuel issues. Looking at the head side of the carb the carb does have a path to vent, just not as much as with the insulator. Haven't ran into issues with flooding the idle circuit though. From some of the things you've posted recently I'd say the first step is to make sure you're getting a good seal with your gaskets. For $12 I'd probably splurge for the NR flat mount adapter, can't think of any way it could hurt! I'm REALLY close with clearance on my air filter (angles one at that) to the frame or I'd use one. Really hope you get it ironed out soon though.
Thanks.
I'm looking into it. From what I can tell, with the NR set up, I Need the 15 degree adapter from NR AND the zero degree adapter for the adapter to turn it 15 degrees back again. The zero degree adapter is to be used with the 15 degree adapter. I think the zero degree adapter is actually a negative 15 degree adapter.
cavfire
auburn, georgia
Only difference I can see between the ARC and NR adapter is the NR adapter is drilled and tapped to bolt the zero degree adapter and has a vent milled into it. Simple enough to do to the ARC adapter.
I think I'm going to give this a try...
3/32" replacement glass 12" x 16" $4
5x 60 grit silicon carbide sandpaper
5x 80 grit silicon carbide sandpaper
5x 120 grit silicon carbide sandpaper $1
1" Dial indicator +/- 0.001" $12
Multipurpose magnetic base $16
Will do final sanding with fine grit wet silicon carbide. Mineral spirits or WD-40 or something.
Not exactly sure how to measure the head thickness to see how much I remove.
Best guess would be to pick a spot on the head and on the block and use as reference measuring with calipers. Dial indicator might be useful to see how flat the surface is.
I would map out at least 4 different check points...(at least the 4 corners) ...and mark those locations with dots and a way to keep track of those locations (Like marking # 1 and measuring clockwise...
As far as checking for flatness...a straightedge in 4 directions : (across the middle, 90° across the middle, and corner to corner both ways,) is a time proven way with much less forgiving automotive heads.
Out of the two: flatness is more important than equal material removal...as the head does not require being 100% 90° to the bore...but as usual, the closer to perfection, the better the result!
EDIT: To clarify...no need to take the block into consideration at all....unless you plan on sanding on it!!!! (Just think about what I said about measuring the head itself! )
So measurements should be taken from gasket surface on head to reference point on head (maybe marking a point on a fin?), NOT reference point on block and reference point on head(point on fin on block and point on fin on head?) after torquing head bolts. I was just thinking of the easiest way to measure. I'll probably measure both ways. It will be easier to see once I get it apart and in my hands.
I'm sure I will drive my self EVEN MORE NUTS, take a million measurements, say the tools are broken, and return them to HF for new ones.:lolgoku:
We are making progress.
We can fix the leaks (I hope, lol).
We can increase the compression (my greatest feat yet).
We can change the angle of the carburetor.
We can rejet the carb if needed.
(Ordered .041, .042, and .043 main jets for gx series, clone, Predator carbs $2 each)
We can rejet the carb for alcohol.
(Ordered 1.5mm and 1.6mm main Jets $2 each
Ordered #60 Pilot Jet $15 ouch!!!)
Ordered the NR zero degree adapter (both parts).
Also threw in a bunch of extra gaskets. lol
Combining shipping.
Yes...off a fin on the head....(hence a dot)....(Sharpie)...quicker and easier than continually reassembling and retorquing head!
Not as complicated as it may seem in explanation...and should only take a minute to check thickness and flatness.
EDIT: And just use dial calipers to check!
How do I change the title of this thread to the 6.5HP Paper Shredder?:lolgoku:
In my next video, I will feed $100 bills into the intake.
---------- Post added at 04:37 PM ---------- Previous post was at 04:31 PM ----------
DD's comment about his carb on his minibike made me remember that this carb may be too big for my cam, chassis, gearing, tire size, and desired torque...
Still have gravity; still have stock carb.
