Desertduler
- Messages
- 1,736
- Reaction score
- 14
Thanks guys, we will see how they work in time.
Here is a small fan that puts out some serious air flow for it's size. It is rated at 220 CFM it is brushless and has ball bearings. If need be I can wire in a rectifier and run this fan for low speed cooling.
This idea is just a maybe and if I do use it I would make a grille and encompass the outer fan housing with aluminum.NOOOOOOOOOOO!!!! (Unless you cover it up with that grill you mentioned! )![]()
No Poboy is wrong, Dont cover it up, It looks cool. Just paint it To look like a Pinwheel!![]()
Beware another stupid idea...
Now that I see that cutout... just for the looks.. mount one of your PC fans right there (matching size of course)
it won't help, maybe even harm slightly (if not powered).. but it'd look awesome!
The hub looks like a great spot for a DYI sticker; if you are worried about how well they hold up, the one I won the photo contest with a couple of years ago has survived several years of abuse stuck to the head stock of one of the CNC's I used to run and is still hanging in there (including surviving a former coworkers attempt to deface/ remove it).
If I use this fan I do not need a battery pack, this engine has it's own AC generator and when it is wired up to the correct rectifier it will put out 12V a and I can run the fan with that if need be.A total Yes..
Well, if possible tilted to sit flush with the faceplate; but yes
I'd even leave it flat black as it is..
just a decal printed (or better one of those round aluminium dog tags engraved) with your name on it on the hub
Awesome.
I think you could velcro a small RC batpack under the tank hidden from view
Sorry, I have a sticker installed already.![]()
I'm pretty sure Sir Robert will give you permission to do so.......![]()
Well....you can have more than one....and I have a pic to prove it!
Wanna see?![]()
More than likely not, now one can see why I cut away the as Alex calls it the "badge area" which would be correct because now there is a lot better chance rushing air to hit the cooling fins as one can see through the opening, but as you know if you have ever followed any of my testing post then you would know I like to prove modifications that I make, I think I will be fine without a fan and then I will cover the opening over with a small thin grille. Time will tell.You won't need a fan, surely. It looks so wonderfully simple and elegant as it is.
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!Well....you can have more than one....and I have a pic to prove it!
Wanna see?![]()
Will you make a cover to hide all those spaces in the block behind the pot?
I guess they would help for cooling, or also just collect dust dirt and rocks.
Maybe some stainless screen.
Its like a Kelly Wood thing.... With a cooking theme![]()
You're just jealous you can't get pot for fitee cents in California!
