cavfire
auburn, georgia
What size jets are you running Bob? FWIW I put a Big Dint GX270 carb on yesterday on a clone with a Dyno .265 cam and 18cc head and with the stock pilot and .040" main I was three turns out on the mixture screw. Promptly drilled the pilot from .0165" to .0195" this morning, but can't recall how far I turned the mixture screw in. I'll say this, that carb woke the motor up all across the board. You're gonna enjoy that overhauled motor once you get behind the wheel.
Stock Jets right now. Not positive the size. I've come across it before but forgot what I read they are. Once I get settled in at work, I'll look for it again. It was just one post from 1 thread, but I want to look again.
---------- Post added at 05:59 PM ---------- Previous post was at 05:57 PM ----------
I bought adult diapers in case accidents from excitement and/or fear!
---------- Post added at 06:03 PM ---------- Previous post was at 05:59 PM ----------
I found this for now. One recommendation was starting with 0.029 low and 0.042 main. IDK if this sounds reasonable for the low?
cavfire
auburn, georgia
That's a lot of jet right there, shouldn't worry too much about using the choke! My guess is that's on a race motor, no choke plate, idling just under a clutch engagement that's north of 3,000 rpm. I'd measure the pilot jet you have, count the turns you have on the mixture screw, and go from there. You're already running so you can't be completely out of the ball park. Bigger pilot can let you get away with a smaller main and can help low to mid range. Similar to using GX140 e-tube in a GX200 carb.
Very helpful. Thanks!
---------- Post added at 07:23 PM ---------- Previous post was at 07:13 PM ----------
The first jetting suggestion was for stock 390 tube.
Another suggestion said 0.025 pilot. 0.055 main with 4x5 ETube (don't k ow if it's stock)
I'll play around. One step at a time. Wouldn't want to risk going to big.
Third source says .028 idle, .042 main for gas.
0.038 idle, .066 main got alky.
Still can't find stock.?
---------- Post added at 09:09 PM ---------- Previous post was at 08:20 PM ----------
http://www.affordablegokarts.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=GPPX
Choose from the following main jets for the stock GX390 carburetor: 100, 102, 105, 108, 110, 112, 115 & 118"
---------- Post added at 09:13 PM ---------- Previous post was at 09:09 PM ----------
Not likely to be a problem......(sorry...couldn't help myself! )
It's cute. Giggle, giggle, giggle....
Are you going to call that cab now? :worried2:
Jk
---------- Post added at 09:16 PM ---------- Previous post was at 09:13 PM ----------
Lol,
I misread earlier.
If chancer didn't thank you, I would have missed the joke.
I thought you were saying not to worry about going too big on the pilot jet.
$1.25 Conronas. Trading hangovers for cash money. Bring your Friends.
I was reading a bunch of info about those earlier. I bought micro carbide bits, but heard high-speed steel bits would be better.
Do you guys use the hand twist chuck drill thing? En espanol, la chingadara?
Jk
Lol,
I misread earlier.
It's sad....I'm sitting here counting beers....and 12 hours before I can get anymore....and the math just isn't working out!!!!
We ran out of Corona or I'd send the Pigeons.
---------- Post added at 01:22 AM ---------- Previous post was at 01:14 AM ----------
No beer before Church on Sunday?
---------- Post added at 01:27 AM ---------- Previous post was at 01:22 AM ----------
u guys did well. I look competent enough on my video that people are asking ME for advice. Lol
Sucker!
I pointed him here so be nice. Lol
---------- Post added at 01:33 AM ---------- Previous post was at 01:27 AM ----------
Got away with my spelling of recommendation earlier.
FreeRunner15
[/COLOR]Got away with my spelling of recommendation earlier.
And your use of English was STILL wrong. ...Good thing for Googles' spell checker and autocorrect.
---------- Post added at 01:38 AM ---------- Previous post was at 01:37 AM ----------
Hey, i really want to see your kart in action. Show a full throttle acceleration vid and compare your ratios to mine.
& another video in 1st person maybe?
As soon as I order a TC bushing, I'll post new videos of it in action.
New 0-30 mph time. New top speed.
---------- Post added at 02:11 AM ---------- Previous post was at 02:10 AM ----------
Unless I find it sooner; I know it is here!
---------- Post added at 02:18 AM ---------- Previous post was at 02:11 AM ----------
I really want to tune the carb first, then maybe order different springs for the TC too.
FreeRunner15
[/COLOR]I really want to tune the carb first, then maybe order different springs for the TC too.
i've done some thought on the subject of TC driver springs and came to the conclusion that the springs allow you to idle much higher without moving and when you DO move..the acceleration and peelout will be brutal if you can keep decent traction. Tire marks EveryWhere lol .
cavfire
auburn, georgia
Bob I just hold the drill bits I'm using for the main in my finger tips and use a pair of linesman pliers to hold the smaller bits I use on the pilot jet. Don't think twice about the TC springs, go ahead and get them now!
I think stock springs / weights for the TAV2 30 series are the zinc/blue combo (paired for engagement at 2200 RPM). The zinc / white combo is paired for 3100 RPM engagement.
First I want to get the low jet sized correctly, then I'll see where happy idle is. If I can get it to idle nicely below 2k RPM w/o engaging the TC, I'll take it. This is going to be off-road-ish (sometimes) and seems like a whole lot of area, from 2200 to 3100 RPMs, under the Torque curve that might be useful in off-road situations.
Correct me if my understanding is Wrong here, but I think I want low RPM engagement (2200 if possible - stock driver springs/weights) and high RPM Overdrive (Yellow Driven spring - 3rd Hole).
---------- Post added at 06:20 AM ---------- Previous post was at 06:18 AM ----------
Thanks for tip on the drills. I'll get both the White Garter and the Yellow Driven. Thanks.
---------- Post added at 06:25 AM ---------- Previous post was at 06:20 AM ----------
What becomes the issue with the stock garter springs in upgraded engine??
I guess I need a dyno now!!! lol
---------- Post added at 06:32 AM ---------- Previous post was at 06:25 AM ----------
Or should I be thinking about it as a tiny area I'm losing under the HP curve?
---------- Post added at 06:58 AM ---------- Previous post was at 06:32 AM ----------
Wish I could sleep after work instead of pondering if there is really a difference between Torque and HP.
I'll take your advice and get the white and go to bed!
cavfire
auburn, georgia
The driver will start engaging before the advertised rpm, I think that's more of the "full lock" rpm. You can run a blue tip with a white tip as well to get something in between 2200 and 3100 rpm engagement.
FreeRunner15
[/COLOR]Wish I could sleep after work instead of pondering if there is really a difference between Torque and HP.
Torque gets you off the line.
But too much torque and you will just keep spinning and not gain traction which will cost you time in a race UNLESS you have a proportional amount of weight on the drive wheels forcing more traction and helping with acceleration.
Think about Spoilers on rear wheel drive cars except spoilers are more effective at speed.
Sometimes having more weight is a good thing. Just depends where it's located and not to have too much to the point where it hinders performance..in this case Acceleration.
Have you seen my acceleration video? That is too much torque. i'm thinking about testing with weight on the rear to improve acceleration.
It was rhetorical. lol
Torque is a rotational force. HP is how fast the Torque can be applied.
Since HP is calculated from Torque.... HP = Torque * RPM / 5252...
Never mind:backtotopic:
---------- Post added at 01:11 PM ---------- Previous post was at 01:05 PM ----------
I actually did a calculation to see the required torque at the wheels to spin the tires. I had to estimate vehicle weight, weight distribution, coefficients of friction between the rubber and pavement.....
I think I decided, "It will be close!" lol
The illegitimate offspring of Schrodinger's cat and Pavlov's Dog.
You mean Poboy's cat. Always lying in the road playing Dead.
