My signature contains part of a Sopranos quote related to Cheese!
---------- Post added at 11:08 AM ---------- Previous post was at 10:23 AM ----------
Before trying a new Compression tester, I tried the old one again.
10psi dry
12psi wet (some oil on top of piston)
changed the tool's screw in adapter for a rubber plug..
20psi wet.
I'm missing one piece of the kit, lets see if they take it back?
---------- Post added at 12:04 PM ---------- Previous post was at 11:08 AM ----------
New tester, same garbage compression. 20psi. Uggghhh.
Do I take the head off????
Let me see if I can get a video of the valve action and show where I am checking lash.
---------- Post added at 12:14 PM ---------- Previous post was at 12:04 PM ----------
https://www.youtube.com/watch?v=fB32diKaGjU&feature=youtu.be
Am I setting and checking at the right spot??? Just want to make sure before I do anything drastic.
rk970
Coupeville, WA
cam timing?
Exhaust valve should be closing when the intake valve starts to open. When that happens piston should be close to TDC.
Also may be a problem with the compression release on the exhaust lobe.
cam timing?
The non continuous motion of me pulling the cord makes it hard to see. The intake starts to open when the exhaust is closing. When piston is at TDC at that point, isn't that TDC of the Exhaust stroke?
---------- Post added at 12:49 PM ---------- Previous post was at 12:30 PM ----------
cam timing?
At the time of installation, I was 1000% sure cam timing was correct. Now only 99% sure. lol
The compression release is a mystery to me. Not sure how it works.
---------- Post added at 12:54 PM ---------- Previous post was at 12:49 PM ----------
Perhaps I should triple check the cam. Easier to pull side cover than head.
I eyeballed a half liter of oil from a 5qt jug. Is it possible too much oil messed up the rings?
cam timing?
AWWW CRAP! !!! Totally forgot about the compression release..(which makes it easier to crank the engine over with the pull cord when starting! !!!!)
Back to square one!!!! (Forget compression for now, or Google up how to disable the compression release! !!!)
I was looking at it before I installed it, I posted a pic somewhere. I start researching now.
WELL....DADGUMMIT BOB!!!! Just what in THE WILD WORLD OF SPORTS. did ya think "compression release " meant?
Just throw a 54 tooth axle sprocket on it....who cares if it runs or not?
Soooo...now!!!!....I don't know know how, I don't know when, and I don't know why....but. I've got this itchy feeling it's a fuel issue now....Define. "Getting fuel"!
Might be fuel.
Put stock Spark Plug back in.
Sprayed 1.5 seconds of Carb Cleaner directly into carb with butterfly open.
https://www.youtube.com/watch?v=RJwVjrOe5hk&feature=youtu.be
Notice the **** eating grin at the end of the video!!!
There is a leak at the fuel inlet on the carb.
---------- Post added at 03:48 PM ---------- Previous post was at 03:48 PM ----------
Choke open plus cracked the butterflfy
---------- Post added at 03:50 PM ---------- Previous post was at 03:48 PM ----------
This was the second time starting after the initial start with Carb Cleaner.
It has started three times. Twice after using explosives to help.
Jrgunn5150
Rudderless
You've got's no fuel then.
Is there anything in the float bowl? IDK if the 390 has the little bolt in the bowl like the 212 or not.
Every time I checked, the bowl was full. If I flood the carb (because it doesn't start), is it normal for gas to leak out?
---------- Post added at 04:11 PM ---------- Previous post was at 04:10 PM ----------
Should I check the bowl right after it dies?
Cool....Kinda weird in a way....but we got there....(y'all don't know about our PMs)....
Was it good for you too?
:lolgoku:
Best 10 seconds of my life since Prom!:lolgoku::smiley_omg:
---------- Post added at 04:16 PM ---------- Previous post was at 04:15 PM ----------
Seriously,
Thanks to everyone who helped me get to this point. Couldn't of even got here without all of your help. Much appreciated.
---------- Post added at 04:21 PM ---------- Previous post was at 04:16 PM ----------
The 1/4" fuel injector line that cost me $4 a ft doesn't fit great on the carb or gas tank. It fits the fuel pump well. I tried little hose clamps but doesn't seem to be doing the trick.
Jrgunn5150
Rudderless
Yes! It could be a variety of issues in the carb, from a stuck needle, to a hung float, some poo in the carb.
The fact that it starts easily on ether, and you have verified spark, means fuel delivery is the issue. Having fuel present in the bowl tells us, you have fuel to the carb, but do you have fuel through the carb at the proper time?
:lolgoku:
Seriously,
Please tell them I helped you...because...they all think I'm just a prick....AND THEY'RE RIGHT!
