Go back and re-lash your valves...and do it on TDC of the COMPRESSION stroke this time.
Intake- intake valve opens, piston goes down
Compression - both valves closed, piston goes up
Power- both stay closed, piston goes down
Exhaust- exhaust valve opens, piston goes back up
Correct?
Set lash at TDC in between compression and power?? Right??
Jrgunn5150
Rudderless
Correct?
The mantra is exhaust opening, intake closing.
Stolen from hot Rod mag so I don't have to type so much,
With the valve cover off, rotate the engine until the exhaust lifter begins to move upward. This is the point at which the exhaust valve is opening (EO), meaning the piston is through with the power stroke, and it's about to begin the exhaust stroke. At this point, the intake valve is closed and the lifter is on the base circle of the camshaft and can be adjusted. To adjust lash with hydraulic lifters, simply grab the pushrod and back off the rocker-arm adjusting nut until you feel play between the pushrod and the rocker arm. Turn the rocker arm adjusting nut while rotating the pushrod until there is no more play between the pushrod and the rocker arm, then tighten the adjusting nut one half turn. That's it, you're done. To adjust the exhaust lash, turn the engine over until the exhaust valve has completed its lift cycle and the intake valve begins to close (IC). Now, the exhaust lifter is on the base circle because the piston is finishing the intake stroke and about to begin compression. Set the lash on the exhaust valve and you're done. This needs to be done for each cylinder.
Ok...this is starting to be a bit of a trend....(and not a good one)....
Now...I'm fairly competent and knowledgeable in both automotive and small engines...and I can tell you right now....NEVER THE TRAIN SHALL MEET!
You're quoting automotive valve procedure, which doesn't mean diddly when setting small engine valve lash....
It's pretty DOMMED simple...as you rotate the engine, both valves will close and pressure will develop in the combustion chamber as the piston rises...COMPRESSION stroke....as it comes to the top...you can drop a pencil or whatever you feel like in the spark plug hole and as soon as it quits coming out of the hole....you're at TDC. YOU SET BOTH VALVE LASHES THEN!
I appreciate a person knowledgeable in automotive engines, but not when they try to share that knowledge on small engines without knowing the differences.
let me try to get this valve cover off. Ultra grey permatex.
I'll be tickled pink too, if I only need to adjust the valve lash settings.
---------- Post added at 06:29 PM ---------- Previous post was at 06:25 PM ----------
I think that is where I set lash before but will check again. I appreciate the help. Wishing I didn't use the Ultra Grey now. lol
---------- Post added at 06:43 PM ---------- Previous post was at 06:29 PM ----------
It seems as long as the corresponding lifter is sitting on base circle, lash for that valve can be set. Since @ TDC of compression, both lifters should be on base circle, this is a point where both can be set.
Well....I could be wrong....(I thought I was once, but I was mistaken! )
It does have what appears to me to be an engine with the valve lash set on the exhaust cycle.
I mean really, not that tough, pull the valve cover....loosen the spark plug till it's barely in....turn the engine over...when you hear air escaping from around the plug...take it out and use the pencil...(or whatever) ....
I guess you're saying you wish you hadn't used the ultra gray because of the cost?
Jrgunn5150
Rudderless
Correct.
Was referring to the cleanup needed before reinstalling. I'm going to work in a bit and need to shower before, but let me see if I can pry it off.
Well....I could be wrong....(I thought I was once, but I was mistaken! ) - ROTFL
---------- Post added at 07:39 PM ---------- Previous post was at 07:00 PM ----------
Valve cover off. Not as much permatex material as I thought there would be. Rechecked lash. Maybe its 0.004 not 0.003. Wouldn't that help make a better seal during compression?
I can feel the compression when using pull starter. I can hear the engine breath when I turn it.
Would I be able to feel and hear it if there is almost no compression, as measured by the compression tester?
YES...but don't discount what I said...MAKE SURE you are on the COMPRESSION stroke and check the lash....
You could be at .010 and running there...but it's absolutely immaterial where you are if you're setting it on the exhaust cylce.
Almost 100% sure lash is set on compression.
Good compression should push my thumb off the spark plug hole, right? If compression is really that bad, I should be able to keep thumb on hole easily, right? I'll test that way after work
---------- Post added at 10:08 PM ---------- Previous post was at 09:28 PM ----------
Also going to check ignition wiring. I verified a spark, but not sure the quality. I seem to remember a strong blue spark last time I checked, this time it seemed more orange in color and not as "strong?"
---------- Post added at 10:11 PM ---------- Previous post was at 10:08 PM ----------
The strength of the spark is revealed in the color. A red or yellow spark is weak and probably will not spark in the cylinder. A blue or white spark is strong and has enough voltage to fight across the spark plug gap even under pressure within the cylinder.
---------- Post added at 10:11 PM ---------- Previous post was at 10:11 PM ----------
This makes me happy!
---------- Post added at 10:13 PM ---------- Previous post was at 10:11 PM ----------
Also was told to try to spray some ether in there and see if it fires up.
Jrgunn5150
Rudderless
I use ether, as a way of eliminating spark as a cause for running. I don't use much, it tends to dry the cylinder of oil.
My Predator has/had a blue spark last time I checked it.
At least I have a plan now.
1. Test compression with thumb
2. Disconnect/ reconnect wiring and check for spark color
3. Spray some ether
4. Suff Provolone everywhere - for sealing properties
---------- Post added at 10:48 PM ---------- Previous post was at 10:45 PM ----------
A New Hope !!!
Jrgunn5150
Rudderless
Don't lose hope, engines are simple, spark, fuel, air, they run! Even if poorly lol. You made alot of changes at once, it's hard to say what the issue is, possibly your fuel pump, possibly your lash.
If you can do physics, you can sort out a go kart engine lol. It's not rocket science :2guns:
Let's see: Poboy rocket science:
Go to Hobby Lobby.
Buy El Cheapo Estes rocket.
Slap together.
Launch!!!!!!!
Search for lost rocket for two hours....
Go back to Hobby Lobby!
Jrgunn5150
Rudderless
I never even got the rocket's built, I was always putting the motors on silly things, all they ever did was start fires lol.
I built one in HS. It didn't fly straight. Lol
I did much better with the rubber band prop plane.
---------- Post added at 11:32 PM ---------- Previous post was at 11:31 PM ----------
Let's Go Blackhawks!
---------- Post added at 11:33 PM ---------- Previous post was at 11:32 PM ----------
How many rocket motors to push a buggy?
I actually did build one of their cheapest rockets, which coincidentally, was one of their highest fliers. I can't remember, used like a C-5 engine I think? It was supposed to be a streamer retrieval, but I made a parachute out of a plastic bag instead.
The fun part was trying to calculate the launch angle so it would land close to you.With that parachute it would drift a long way sideways on the way down. I launched at close to a 45° angle on days that weren't partictularly windy.
Never had the fancy launch station, just a stiff wire, some speaker wire, and an open hood...(car battery).... Actually never lost a rocket and usually had them land within 30' .
The guy who told me to put my thumb on the hole, said it probably won't blow my thumb off, but it should be difficult to keep there and I should feel some heat.
"Difficult" is subjective and I thought it was fairly easy to keep my thumb on the hole. I did feel the pressure, but having not done this before I'm not sure what it should feel like. Tomorrow I will try to exchange the compression test kit and maybe try a wet / dry compression test. Also I've heard that throttle should be open during compression test. I may have had the choke on.
---------- Post added at 03:51 AM ---------- Previous post was at 03:47 AM ----------
Also spark seemed more blue, with a little orange, now that I looked for the color.
---------- Post added at 03:53 AM ---------- Previous post was at 03:51 AM ----------
New method of sticker delivery???lol
Or to shoot down pigeons???
