I'm pretty sure that's the piece that wraps around the head under the tappet cover.
Ok then, Looking at my NON hemi 212. I would definitely put that back on. It attaches right off the fan and blows air across the COOLING fins on the head. Especially since you have built this motor and plan on running high RPMs that will build up more heat.
So stop what you are doing now and get that OUT of the trash and put it on.
Thanks.
Remove studs from head, Put them in adapter, bolt adapter to head where studs used to be (using now enlarged for no good reason recessed bolt holes). Should still work fine (may need a washer).
---------- Post added at 06:34 PM ---------- Previous post was at 06:32 PM ----------
correct
---------- Post added at 06:35 PM ---------- Previous post was at 06:34 PM ----------
I still have it but will have to wait til I get back from Vacation
---------- Post added at 06:37 PM ---------- Previous post was at 06:35 PM ----------
You don't think 42mph will cool it enough??? lol I'll put it back on.
---------- Post added at 06:49 PM ---------- Previous post was at 06:37 PM ----------
Or maybe 48mph if i put the big tyres on it. i'm guessing 15+ HP but really don't know what to expect.
Jrgunn5150
Rudderless
Thanks.
So that was the problem? Good lol.
I threw mine away, maybe I should go get it out from the trash too lol. I gotta quit throwing thing's away
Yep you were spot on! Wish I didn't drill so quickly. Wish I started piecing it together first. Worst case would involve drilling and tapping but probably not a huge task if needed.
Jrgunn5150
Rudderless
I've had my Captain Caveman moment's too lol. I'm really looking forward to seeing this thing run.
So that is what a carb looks like!!!
27mm vs 19mm
Doubles the area of the passage on the engine side!
Too bad, it's going to have to wait, but probably better than rushing.
Ok so you keep mentioning it.
Where is this Vacation taking you? and for how long?
---------- Post added at 08:52 PM ---------- Previous post was at 08:48 PM ----------
It might. I think Desertduler is building his 2 stroke without a fan and expecting/hoping the wind keeps it cool.
I mean these are made to be stationary industrial engines, So yeah with the 42/48 mph wind in their face they may be fine. (shrugs)
Cruising the Caribbean. Family Vacation. 20+ family members. Retirement Gift from parents (for themselves) to get family together. Planned with my ex.
But "I simply got rid of her" lol
and didn't find a replacement in time!!!
9 nights avoiding international jails.
-Captain Patchy Beard the Pirate
---------- Post added 04-02-2016 at 12:13 AM ---------- Previous post was 04-01-2016 at 11:54 PM ----------
Just to clarify, they retired...Not me... and they bought the family a trip. Nice right?
---------- Post added at 12:26 AM ---------- Previous post was at 12:13 AM ----------
Any last minute advice....
Going to order some at least a bushing for the TC (or 5) to be here when I get back. I'm sure I'll find the old one, but it was already showing wear and I may go through them fast with the new engine mods. May get stiffer springs for TC as well.
Need some fuel line and vac hose for fuel pump. I'll see if available locally.
Need to rethink throttle plate. 390 carb butterfly spins differently.
Maybe a 0.027" gasket. lol
maybe a bunch of TC belts too!
Jrgunn5150
Rudderless
I smoked my belt after my brakes hung up on me while teaching my girlfriends three sisters to drive, real bummer after I spent an hour getting the truck running to haul the kart down to the fairgrounds, rounding up three teenaged girls, etc etc to bust the only belt I had.
I definitely plan to keep two on hand from now on lol.
After I pick up my sister from the airport, I'll see if I can reverse the action on the stock throttle plate to use with 390 carb
The carb adapter was ground down on one corner to make clearance for the valve cover.
Really wanted to port the adapter, but too impatient at this point. There is a noticeable step increase in area as air/fuel leaves the adapter and enters head.
So I know there should be room for improvement if I get a thinner head gasket and port the adapter in the future.
---------- Post added at 04:51 PM ---------- Previous post was at 04:31 PM ----------
After reading this
http://www.diygokarts.com/vb/showthread.php?t=21052
I hope this carb isn't too big.
I can always go back to the old one.
---------- Post added at 05:07 PM ---------- Previous post was at 04:51 PM ----------
"Making any adapter seal on these engines has little to do with the adapter its self. It has more to do with the fact that I have seen very few a port surfaces on a Honda, Clone or Predator engine that are truly flat. The plastic insulators will flex around this unevenness and seal off, this is also one of the reasons people have trouble with the plastic ones cracking or breaking. A billet adapter will not flex around a port surface that is not flat. The simplest way to fix that is to run two of the D shaped gaskets between the adapter and the head. This will produce a seal almost every time. Also when you are tightening down the bolts on the adapter be sure NOT to tighten one all the way down before the other. Alternate from one to the other until both are tight and install the studs after you install the adapter on the head. Silicone is never needed on any part of a properly built race engine, it is nothing more than a band-aide and is never as good as a properly installed gasket. As far as jetting for gasoline, I start with a .029-.032 on the low and a .042-044 on the main using the stock 390 Etube. Timing 31-32 BTDC. These adapters are designed to run on a 15 deg mount."
http://karting.4cycle.com/showthread.php?67496-Gx390-carb-on-a-Predator-212-question
