Sh!ft
New to this whole go kart thing. I've mostly worked on cars and motorcycles.
I took this picture the day before picking it up. The seller stated that it only needed a drive belt, that was false. I checked it over the best an amateur like me could and found that the cvt pulleys needed replaced, the brakes need attention, the drive chain was rusted almost solid, the wood underneath the seat was completely rotted and the spring from carb to governor was broke. The frame was in good shape though, the engine ran, and the price was right so I went back the next day to pick it up. Had to remove the roll cage and steering wheel to fit it into my suv.
http://i845.photobucket.com/albums/ab12/civicejguy/Mobile Uploads/20160314_173039_zpsctezzmhc.jpg
So far I've scrubbed the chassis down with soap/water and removed the ruined lower bench seat. Got both pulleys and the chain removed in preparation for a tav2 cvt kit but after some more research found that I should be able to restore the pulleys I have. Also found that the driverside part of the rear axle is bent about 1/4-1/2in after placing a screw driver close to the rim and spinning the wheel. Hopefully I'll be able to bend it back pretty straight.
http://i845.photobucket.com/albums/ab12/civicejguy/Mobile Uploads/20160316_010817_zpsoc13ehos.jpg
Here's how clean I've been able to get these rusted pulleys. Top pulley shows the condition they were in and the bottom two after being sanded with 220 grit. Then wire brushed after sanding and polished them with metal polish.
http://i845.photobucket.com/albums/ab12/civicejguy/Mobile Uploads/20160316_014933_zpsxxljsidu.jpg
