Anybody have experience with increasing compression on these 212 Hemi engines? It is all brand new to me.
I don't want to do any Milling.
I have a Black Mamba Jr Cam (0.275 lift) and want to use +0.020 Rod, stock piston, and perhaps a thinner head gasket, but I don't know how much room I've got to work with.
I don't want to tear it apart yet because the weather just got nice. I will measure myself after some play time, but wanted to start this discussion before so I have an idea.
Thanks in advance.
Going on a buggy with 30 series TC, 7.5:1 gearing and 16"Tires. Max RPM 5000 (Cam not installed)
---------- Post added at 04:33 PM ---------- Previous post was at 04:16 PM ----------
Something like this
http://www.oldminibikes.com/forum/h...predator-hemi-212cc-compression-pump-gas.html
Here he used the thick (0.041) gasket but Milled 0.030
http://www.oldminibikes.com/forum/honda-clone-predator/102074-hemi-head-predator-build-60363-a.html
Well...what You do is go to ToysrUs....(or similar) ....and get some modeling clay....assemble the engine and turn it over...(leave the spark plug out....so the excess clay has a place to go...and it will give you an EXACT idea of the clearances involved.....
Thank goodness you're not an idiot (like some) ....because I don't want to post such a simple solution 3 more times!
I bought the clay already. I'll take the head off after I play for a while. I wanted to see what others have had success with. I guess " in the hole" varies more than other specs with this engine
gman3850
gilbert az
My engine is basically the same u are building.
Hemi
Jr cam
.020 gasket
.020 rod
0 decking
Billit flywheel 32 degrees
Hemi
Jr cam
.020 gasket
.020 rod
0 decking
Like I said I'm new to this...
Does 0 decking mean the piston sits flush at top dead center or that no milling was done?
I've been looking into gasket selection. I see 0.010 or 0.040 for the Hemi Head. I've seen 0.009, 0.018, 0.027, 0.036, and 0.045 for Non-Hemi (says bottom left dowel pin hole needs to be enlarged for Hemi). Where did you get your gasket and did you have to modify it
Is it ok to have some Pop out? A different thread had a guy saying most of his hemi builds started at 0.015 to 0.018 in the hole
---------- Post added at 07:19 AM ---------- Previous post was at 07:12 AM ----------
Wait....what???? I'm I on the right forum? Two folks exchanging useful information without issues? Pinch me....I think I'm dreaming....
Thanks guys!
Wait! I could still mess up this exchange of info IF I post the pics of the Full Scale Clay Model Piston I have baking in the oven right now.
Just tell me once, SEE I got it:thumbsup:
---------- Post added at 07:25 AM ---------- Previous post was at 07:19 AM ----------
On a side note: I think I saw the "Clay Model Pistons" at OzzFest one year
Dang...I get confused so easily these days....and my memory isn't what it used to be....was that the year the B52's and FreeBaser15 played?
The Clay Pistons may have opened for FB15:lolgoku: But the lead singer for the Headliner started on fire after a mishap with pyrotechnics and grain alcohol
gman3850
gilbert az
[/COLOR]On a side note: I think I saw the "Clay Model Pistons" at OzzFest one year
Well first make sure to measure deck height of the piston to Mack sure u can add the longer rod but yes a small pop up is fine. Just use the thicker gasket.
I have booth the 0.018 which I call a 0.020. And the 0.010. The 0.018 is in the motor with the longer rod and the 0.010 is in the motor that still has the stock rod. And yes I had to modify booth but it was just a tiny bit.
With the jr cam I recommend the fly wheel at 32 degrees. Also I have a Robertson torque tube loop header and a muffler. With a comet 30 and a 9 on the clutch side and 54 on the axle with 18" tires I top out right around 49mph. I have 26lb springs and turn around 5100 rpm. If I go to the 8t sprocket it had almost too much lower and and had a really lazy shift
YOU DA MAN!!!!! Thank you soooo much!!!!
gman3850
gilbert az
U could feel the the low gear max out and would hesitate for a few seconds than shift. With the 9t it still has it but not as noticeable. The 10 was perfect but had the tendency to shred the belt a lot quicker. So I stayed with the 9
Just curious if you tried making any adjustments to the TC springs and what seemed to work best?
Made an $18 purchase today. I'll spend a few weeks learning as much as possible before even taking the head off or buying the accessories. I've already learned that I shouldn't try to do too much. Just planning on smoothing rough edges. (or maybe try to fit a 28mm intake valve?? lol, jk). I really have no idea what RPM this engine will turn with the new Cam, rod, gasket, possibly new carb, plus any other work I do. It topped out around 5000 (35mph) in my neighborhood with lots of turns.
I'd like to gear the build toward more low end grunt. I don't have too many places to ride and will be bringing it to off road parks. I'm also Ok with doing 45mph (6500RPM) ripping across the sand dunes too:auto: if that is what it can do.
gman3850
gilbert az
If going for low end you don't want to port a lot just smooth up rough casting. Smaller arbs and smaller ports is what u want
KartFab
26 lb springs, 5100 RPM? You could almost get away with stock springs at 5100 rpm. Why not 18 lb springs?
