Kelly Wood
The Mad Kartist
Take this pic for example. (thanks Shaun of DIYgk forums)
First off, the clutch would be replaced with a torque converter. then upgraded TC spring and gear. Now that jackshaft is used to amplify either speed or torque(however you choose to gear it). Add 1 more and you should definitely see the difference in performance if the engine can handle the power needed.d Logic?
Yup, with that, um... logic (hard to say that word here and have it mean something)... you'll be doing a mighty 10 MPH. Sweet.
Then that predator will explode.
"If the engine can handle the power needed?" What does that even mean?
<-- if you see this, your post is either very cool... or people are just waiting for you to fail killer.
