Making a Go KArt 4wd?
As far as i know you can make an awd go kart unless you have 2 engines
That's not true in any way...
Drive train out of a scrap import quad will get you most (if not all) of the parts you would need. Expand your horizons.
The most difficult issue is finding/making hubs that drive & steer; once you nail that, the rest is (relatively) easy...
NotSoMasterMind
South lyon michigan
Unless you can find a gearbox i dont think you can, i guess you could just run a drive shaft up and down the axle, live axle in the back and shaft running to each wheel, but too complex to explain
It's not that complex, chain from clutch to J/S with three sprockets, one sprocket for clutch chain, the other two for both axles; simple really...
Driving the axles is not the issue; as I stated previously,
The most difficult issue is finding/making hubs that drive & steer...
It would only be icy here for about 2 minutes if that happened here. LOL
Yeah....I heard an 18 wheeler crashed hauling a load of ice...and people lined up to get it....and only the first ten people got ice!!!!
The next 10 got cold water....the next ten warm baths, and the last ten boiled ostrich eggs....
Mammoth
Durham, CA
When you mentioned 4wd kart i thought of this one which is on affordablegokartparts web site.
