help with clutch
bigdogder
Will i be able to get a clutch to fit this style of shaft??
That looks like an extension of some sort for a pump or the like... This is kinda an exception to the rule....
With that being said.... Probably not cause most pumps have a tapered shaft...
bigdogder
Its not an adaptor on it. Not got anything to check size but i think its 1". If i was to strip the crankshaft out would there be anyone that could machine it to 3/4" and put a keyway up it so i can get a clutch on it??
cavfire
auburn, georgia
The shaft is clearly smaller in diameter as it exits the side cover. I'm with the other posters in thinking it's an adapter, possibly threaded on. Otherwise how could you ever pull the side cover or replace the oil seal if it can't make it over the shaft.
Good spot my friend! !!! Yeah....so, Anderkart...yeah, there's a keyway...(under that sleeve.)
And Bigdogder....you can say it ain't an apple all day....but that's not part of the crankshaft!
