Building a monster takes a community
Kahrese lee
Hello I shall be beginning to build something I think will be exotic and amazing I plan to create a half size 1970 dodge charger pretty much identical to Dom's from the fast and furious #1 with a Honda CBR 900 RR engine I already have the full bike runs like a dream
Kahrese lee
I'm 19 I've been doing go karts minibikes lawnmowers anything with a motor I could get my hands on and I've been riding motorcycles and dirt bikes for a bit now as well I currently daily my 1994 fireblade this will be my first time building my own frame from the ground up my budget right Now I have $800 I feel that will be enough to start the frame and I just picked up a lot more days at work I should be able to make $400 a month spare for it
Kahrese lee
I have a welder and I can cut myself I've done so previously for other projects and the frame I plan to basically square it I'd like to use square and just reinforce it so that I don't get all the tube frames are stronger attacks I feel square would be better for this type of body that I want will build the frame and possibly use clay to sculpt with fiberglass the body parts like some people do to make they're own body kits for cars or I should just use sheet metal and have it bent into shape for a much stronger body that won't be completely ruined if I ever roll it or some other bizarre event
Sounds like quite the project. But first if you want any help here, you need to learn what these are,
? ! , . : ; " ( ) Google Punctuation.
Kahrese lee
Alrighty I can do that, I could use some help with what I should go with for a nice Axel. I doubt I can use the normal 1inch from bmikarts I'll get one cut specially, I'd use one off a 150-250cc buggy that people sell but I feel I need a longer Axel to have my wheels further apart for more roll resistance.
Axles are available in sizes other than 1"; most suppliers also have 1 1/4"; BMI make custom axles IIRC...
The length of the axle is determined by the dimensions of the car, which involves you doing some math...
Kahrese lee
So has anyone used a 1 1/4th axel for a kart with 100 plus hp not the normal 25hp or less motors
It's not necessarily about the axle itself but, what you put on it...
Unless it takes a hard hit, there's not much that will damage an axle but, I've seen a few sprocket, brake & wheel hubs explode or simply let go under "normal" operating conditions...
It takes a lot to bend or damage a piece of 1" solid steel, it takes a lot more to damage 1 1/4"; it doesn't take very much at all to destroy an incorrect hub...
Kahrese lee
OK thanks for this information any one know someone that could give some information on good set of wheels to use?
