trajectory7
- Messages
- 2
- Reaction score
- 0
I currently came into possession of a 6.5hp Predator Engine mounted on a go kart designed for off road use. Initially the kart was set up with a jackshaft connecting the engine to a live axle. However the teeth on one of the sprockets melted down, causing the chain to slip. So i removed the jackshaft and remounted the engine for a direct connection from engine to axle.
Before:
After:
Now, here comes the problem. When the kart is on blocks the clutch will engage and the wheels will spin. When it's on the ground the clutch does not want to engage no matter how much the throttle is opened. Is the clutch burned out and needs to be replaced? The kart is currently geared at 10/30, which I assume is too small given size of the tires (18" rear wheels) and weight of the kart for a centrifugal clutch to handle. Can I solve the issue altogether by installing a torque converter?
I'm pretty new to go karts, and not completely there on mechanical lingo, so bear with me. Thanks for the help in getting this thing running, everyone!
Before:
After:
