The Rust Rocket
Worcester Massachusetts
the front most piece of angle iron acts as a tie rod. and the cable pulls on the back of the steering spindle. i used angle iron for the spindles at first with no lower suport. so far ive upgraded to the no weld spindles with 1\2 T's and a flimsy lower control arm just to suck in the camber a little. The thing steers like a brick still because there is no caster to the front end so it a bit jumpy. halve to hold on to the steering wheel with ur life. But its not un bearable
Vids 2 come
I like karts
Rotary Power!
Alabama
Mind if I steal your idea Mozart? Me and my friend are going to build a kart entirely without welding, and it'll probably end up lookin like yours. True piece of genius there :thumbsup:
recent pics
took the kart out today tried to make a vid but found it imposible to drive and shoot at the same time. as soon as i get someon 2 hold the camera ill have a good vid up on here so far no one wants to be near it while im driving:surrender:
eronann
MA
This thing looks like the erector set I use to play with when I was 10 years old only BIGGER.
Love it......:wai:
Buick455
got any pictures of it?
Florida
Holycrap dude, you up to date on your tetanus shots, lol… Still, I think its awesome use of junk. One question though, where the he11 did you find that much rusty punched angle?
it was a large shelving unit at one time dismanteled my dad found it somewhere. very flexible stuff very heavy tho.
does about 35mph and still has just enough to go up hills with a head start. id really like to make a lighter frame tho.
kibble
I banned myself
Here you go dude, clean it up a little bit:
mini monster
Perth, Western Australia
Hi, Top stuff.....see anything can be made without the means of $$$$.
Looking at your steering and just a thought, Some old boats came out with a push pull steering setup uterlising same sought of cable.
The sleeve that slides onto your steering shaft and can be fixed by screws gets wrapped around by the cable a few times so that each other end to your tie rod stays tight,then there would be no slack and would make steering direct.
Cheap and safe option and could possibly get from local boat yard or tip.
Love the rear snow chains....
Jason..
thanks and i like the rust btw and will stick with it. gives her character:drool5: mean while my girlfreind agreed to shoot some footage of the kart in action for me probly on monday so may have a vid by wed };";{
