Brakes On A Jack Shaft?
Wtf
Mad Max
What? No billet connecting rod? Bye bye Predator....
lol, yeah no, I've owned quite a few of these never had that happen... and since they cost more then the engine I don't see the point of it.
I have however blown multiple valve springs and bent multiple valves. Thats why I always install those the day I buy them.
But spending 129 dollars on 90 cents worth of aluminum to protect an engine that cost 99 dollars??? ugh yeah that's a bad investment in my book.
Interesting build, kinda cool...
I hate to be controversial... But I see a few things that I question...
Although the quality of the picture might be to blame ... It apears that you have welded a few things to the shafts used... Why??? (That is kinda the number one thing not to do when making these types of machines, and with that being said... I hope you grounded the shaft at least, not the frame when welding. Saving the bearings for a little while longer)
Also it apears that you have welded the brake caliper bolts to the frame... For the most part typically they use a grade 8 or 10.9... You would need to preheat to prevent cracking..
Also flux core welding will also hamper proper fusion seeing how there is no surface prep grinding on your frame and all of the frame joints..
Iron John
NA
Holy moly, there is a lot of aerospace concern for a yard mule that hauls stumps and rocks.
If it works for the OP, great. If not, he'll fix it.
OP, really nice use of what you had laying around to get purposeful work done.
That's true....but I think Mckutzy was right to point out the flaws...as the next guy looking at this thread may be building a kart that goes fast enough to kill himself....
Yes we aim to keep our brethren and otherwise followers safe... To the best of our abilities.
Wtf
Mad Max
Try to answer these questions for you, only the sprockets are tack welded to the shaft, because it eliminates the possibility of slipping significantly more then set screws, this is not a kart im racing or passing down to my children... I just need to move some rocks with it this summer and fall... if after that it lives through till next year, well great.. if not, well....if he dies he dies...lol
Additionally, Yes I grounded the shaft. The brake caliber bolts are welded head side to the frame, it works perfectly and can be easily taken off to replace pads, as they are nut side out. Also I own a grinder or 2 so if don't like it, ill cut em off...lol... and there was surface prep on every weld, everything was ground bare then touched up with red oxide primer.
And long story short it works exactly as intended.
---------- Post added at 04:50 AM ---------- Previous post was at 04:43 AM ----------
Yeah rpms = speed not torque. So taking it out is extremely unnecessary
Not exactly, your initial acceleration is dedicated partially by how many rpms you have, if i have one wheel stuck between rocks, being able to rev up a bit more may be the key to getting out.... yes when moving already RPMs allow top speed not torque...
I think a lot of guys are having trouble wrapping their heads around this project because they are use to karting in a different way...
---------- Post added at 04:51 AM ---------- Previous post was at 04:50 AM ----------
Lol seriously.
I would have posted sooner but my account got deleted... wtf? Any way ill post some pics in a bit
No it didn't. Kaw is still an active member on the database. The profile has not been deleted or banned.
Are you sure you didn't just forget the password? I can ask Robert (the site admin) to get it for you
Wtf
Mad Max
No it did get deleted, he created a new acount called "kaw" to replace my original account.
My acount user name was "Admin"... so I know why he deleted it...lol
... however he did leave it open so I feel like if I snagged it, I should have got to keep it... :)
So why the heck have you got a third account. One with a highly inappropriate username. Did you not like Kaw? It is not deleted, so why create a third
You might lose the one you have now too
Wtf
Mad Max
I created one account, it got deleted without informing me and for with out breaking any rules dictated on this forum... I created a second account which i am using right now... I did not create the "Kaw" account... nor do I want and account called "Kaw".
And whats highly inappropriate about my user name? WTF means "Well That's Fantastic"
:popcorn:
Wtf
Mad Max
I bet 99% of the members would disagree with you
If some one thinks it means something else, then they are ready have an inappropriate mind... so no harm done there. :cheers2:
---------- Post added at 07:42 AM ---------- Previous post was at 07:39 AM ----------
Seroiusly? It never crossed your mind how confusing that could be for future members?
See...his username becomes more logical all the time....it's offensive...but apparently he's been so from day one....
Why.....that's fantastic!!!!! or....What? that's foolish.....IDK....WTF....
Wtf
Mad Max
Well its already my sign on for most of the websites I own or run... so pretty much every other public site I sign into a test that first... very few leave it open, as its usually utilized or dedicated...
And no I don't see how that's confusing, if anything its accurate... now if I put "Site Moderator" or "Site Owner" Then yes that would be confusing... lots of people use their job title or hobby intermingled into their user name.
And seriously, what's the worst that could happen?? Someone accidently ask me to fix an issue and me not know the answer?
lol... theres a lot of bigger issues out there to worry about...
