... Also it doesn't look like the coil really touches the flywheel
Not suppose to 'touch'... that would be anti-productive
. There 'should' be a slight 'gap'. Take loose the 2 bolts holding the coil in place. Take a normal business card, and slide it between the coil and the flywheel, release the coil to allow it to magnitize itself inplace. Tighten the 2 bolts... and slide out the card.
I have moved my pulse hole for the fuel pump to where the oil sensor used to be is that ok?
Im guessing youre talking bout the oil sensor wire hole... It's '
doable' however,
that area gets
ALOTTA oil traffic and that would have a
REALLY good chance of slinging oil into your pump(
which will 9/10 times prevent the pump from operating). The
normal place(
s) to pulse from are the valve cover and '
some' tap the hole of the governor arm (
that was removed) and pulse from there... I personally would NEVER recommend tapping a hole in a block/case... valve covers are
ALOT cheaper, if an
occurs.
