got my first mini bike project!!!
boriquaracer
rhode island
Hi guys!! Short time member, long time browser. I really enjoy everyone's posts here. I picked up this mini bike last night for $30. I also picked up for free a rotatiller and snow blower. I got the Rota tiller running. It has a 6.5hp engine. Brand is greyhound.. so I figured I'll use the motor from the tiller for the bike. Here is a pic. I don't know the brand or if it's a home built/modified. Once I take it apart and have the frame powdercoated I'll go from there. Thanks!!
Make sure the motor has a straight keyed shaft and not tapered one. Clutch can't mount to the latter.
boriquaracer
rhode island
Thanks for the warm welcome guys!! I'm going to start taking apart the Rota tiller this week so I can see what I need to get to make it mobile.
FYI Your Greyhound 6.5 is a clone of a Honda GX200. From what I have been told on this forum. It is an exact clone, comes out of the same Chinese production line as the Honda. As opposed to the predator vwhich is very close but not an exact clone. Something about patents and copyrights.
colestreasures
Kentucky
It has use to be a mini chopper / maybe something else wrote all over it, and x2 on that 49cc style engine mount.
Cole
There is a nyloc nut on the center of the throttle lever, that everything hinges on. Loosen that nut, just enough that the throttle springs back closed when you push it open. That is how we make these go. I usually find a spot to put an extra return spring on there just to make sure the throttle does not stick. Also of course a good kill switch on the handle bars can help too.
There a little box on the front of that motor with some wires that got to the shut off switch. The box is a low oil sensor kill switch for stationary equipment this motor can be used on. On a mini bike this will kill the engine every time you lean or turn. If you disconnect the wire and run it to the handle bars and wire in a Horn or other momentary switch it makes a great kill switch. We can look at this later on when you get there for more detail.
