2015 - Old rider mower-now kart
Exactly! The winner is the machine that appeals the the majority of voters; it doesn't matter how fast it goes, how shiny it is or how long it took to build, it comes down to what the voters like!
Don't count yourself out just yet...
crazykart
Crazy member
Swartz Creek, Michigan
Ah that would explain it then lol.
You have just as much a chance of winning as everyone else does. Personally I like it, a lot. I might just vote for ya over my own lol.
dwcopple
backyard hooligan
Mid-Michigan
made a chain tensioner outta some junk parts I had lying around. The chain is cutting into the roller already so I am gonna get one off ebay to toss on there.
With the rubber isolators you'll probably still need a tensioner....but you need to fix your alignment issue or your chains and sprockets aren't going to last very long.
Desertduler
DW, you have that tensioner on the wrong side of the chain,you want to install it on the non pull side of the chain or it will not work.
:smiley_omg: I totally missed that Brett, do you see the misalignment or no?
EDIT: Just so everyone can see what I see....Look at the frame and axle sprocket and see how nicely it aligns with the frame.....then look up towards the engine...(keep in mind, things get smaller further away) and compare the distances between the chain and frame.....
DOUBLE. EDIT: Ummmmm....The skewed wear lines one the tensioner should be the second clue....(and probably why they are there....)
Desertduler
We are nuts? thanks, you know sometimes indeed the camera does distort images,I believe you,how about watching what you call people that you don't know that well most certainly when they are trying to help you.
Desertduler
Yup, words can come out wrong and be taken wrong,that happens sometimes,looks good,to get less wear on your tensioner and chain links one can make a roller that just rides on the chain rollers inside the links and also another small idler sprocket with a bearing inside but now that you have the tensioner in the right position it will be good to go and indeed your sprockets are aligned correctly and it must have been a illusion from the picture just like you said.:thumbsup:
Sorry....still looks off to me...it would have been interesting to see a pic of a staightedge against the side of the rear sprocket touching the drive sprocket while you had it all tore apart....that would have proven something...
But its all good....it's not my chains or sprockets....so...I don't really care...I did my part to show what I thought might be a potential problem....it's on you now.:thumbsup:
We are nuts? thanks,how about watching what you call people that you don't know that well most certainly when they are trying to help you.
Ummm....I'd say his chances are a little slimmer now....:lolgoku:
dwcopple
backyard hooligan
Mid-Michigan
Spec sheet inspired by DD:
frame, modified Huffy 1950-60? mower
custom bent/welded spindles made from 5/8" threaded end stock
front tires/rims from rear engine rider of some kind
steering stem off an Arctic Cat 4x4 ATV
1982 Yamaha XS400 Maxim handlebars
bicycle brake handle/lever
throttle/kill grips from Chinese mini chopper
Briggs 5hp engine off a snowblower
custom air filter/intake
straight conduit exhaust into a threaded mower muffler
custom seat risers out of box stock to clear engine
custom gas tank mount
floorboard made from an old student chair from a local elementary school
12tooth cent clutch
60 tooth rear sprocket/drum/hub
4.5" band brake, lever controlled
custom axle made from a yard/garden trailer
chain tensioner from scrap
odds and ends/brackets/bracing from scrap (mostly bed frame angle iron)
wheelie bar with roller blade wheels
