MatthewD
Senior Member
Hi,
I recently just bought another drifter kart for free! I had so must success with the old one that I thought I'd buy another one.
Anyway, I'll be making a thread about that in a while when I get some pictures of it.
I've got the engine running, but it will only run on choke and will not take the gas. Also it idles at about 2000rpm (enough to engage the clutch) even when the idle screw is removed. I've checked all springs etc and they seem intact.
I've tried this with several carbs (they are replaced ones off other engines so may not be working properly) and they all show this result. I did think it was an air leak but I can't find anything that would show that. The rear carb "plate" was cracked but I've replaced that and it made a slight difference.
A new clone carb is only about £12 so should I buy a new carb and see if that fixes it since it is quite cheap?
