Honda 5.5hp Clone Issues
MatthewD
Senior Member
Northern Ireland (UK)
Hi,
I recently just bought another drifter kart for free! I had so must success with the old one that I thought I'd buy another one.
Anyway, I'll be making a thread about that in a while when I get some pictures of it.
I've got the engine running, but it will only run on choke and will not take the gas. Also it idles at about 2000rpm (enough to engage the clutch) even when the idle screw is removed. I've checked all springs etc and they seem intact.
I've tried this with several carbs (they are replaced ones off other engines so may not be working properly) and they all show this result. I did think it was an air leak but I can't find anything that would show that. The rear carb "plate" was cracked but I've replaced that and it made a slight difference.
A new clone carb is only about £12 so should I buy a new carb and see if that fixes it since it is quite cheap?
Did you clean any of the carbs. My first greyhound harbor freight clone acted similar, only running with choke. I just pulled off the carb bowl, unscrewed the jet cleaned it off and it ran much better. and it idled too high but the Previous owner had some crappy linkage causing that.
MatthewD
Senior Member
I have, but it didn't make much difference. I ordered up a carb last night just because I needed to buy a seat and tubes so I decided I would buy it then.
:iagree:
Also concentrate on the idle circuit which runs along the left side of the carb & below the black plug below where the idle screw goes (if you need pics, let me know)...
Yes I know where you are talking about but since a new carb was so cheap I decided to go for it anyway.
Umm, what? :lolgoku:
I will go into more detail when I get my thread in the Builds section made but I got it from a relative who was looking to get rid of half his shed :D Yay for free stuff! :lolgoku:
MatthewD
Senior Member
Update!
Update
I got my new carb delivered, fitted it on and it improved slightly. Then I think, hmmm is there a gasket? Take it all apart and bingo, there's no gasket. Go and take one off my parts clone, and the thing runs beautiful. Then today, she started running just as it had a few nights ago. Take her apart and the gasket is there. Put another one on on-top on the other gasket and it doesn't make any difference.
Does anyone know what is going on with this thing? It's got really beyond me! I've never had any of these problems with my Genuine Honda GX160.
One of the issues I had with my clone was the plastic airbox did not fit tight. Like I said previous owner had a goofy linkage that screwed up the air box. It allowed dirt to get in and constantly get that jet dirty. We run the karts in a lot of dry dusty dirt. It was so bad my daughter (12) knew how to fix it herself. I was wondering if you had a similar issue dirty or loose air filter or even crud/ dirt/ rust in bottom of your fuel tank. Whatever was messing up your old carb has messed up the new one. Sounds like you need to clean everything. intake fuel lines tank and now new carb. That may solve it.
:iagree: Obviously, the carb is causing the issue but, it's not creating the issue; clean everything including the tank, lines & fuel cut off switch...
Do you have a filter in line from the tank to carb? If not, GET ONE!
MatthewD
Senior Member
Right guys, I cleaned everything tonight and it's still not running right. However, I took the plug out and cleaned it, put it back in and she went good for about 30 secs but seems to be running rich and returned to the previous problem.
