itsathepete
- Messages
- 7
- Reaction score
- 0
Ok first post.
I recently found kart on CL and have no idea what brand or model it is. Got a new axle and bearings that fit perfect and say they are for Kartco karts. It has a 5hp Tecumseh Enduro with a 10 tooth clutch and 54 tooth drive sprocket with 13" rear tires. this gives a ratio of 5.4 and GPS indicates top speed is 36 mph. This calculates out to 5000rpm top end. Can I assume the governor has been removed? I didn't think these were supposed to run over 3600rpm. If the governor is removed, I'm sure it would be best to not run the thing wide open too much so as not to destroy the engine. I'm about 180# and it's pretty slow to take off and won't climb any hills from a stop. Can I assume this is due to the gearing, or is the engine just not making any low end power? thanks
The valves should start to bounce at around 5000rpm, protecting the engine...
