HippieHeadShot
Then I would also need to get a back plate right?
Sorry to be so big on the questions but I really have no idea about TCs
What did you search? I can only find 30 series, wouldn't that be to weak to handle the 13hp?
A 1 inch bore should handle from a 8hp up to a 18hp ,i have one on a 16hp and a 13hp engine and it works great. My neighbor has one on his 3 wheel kart with a 13hp and it does good. When you look check the specs on it , it should tell you what engines its made for.
Cole
Could you link what you have found?
The 1" I am finding are all rated only 8 - 13 HP which worries me being at the edge of that scale. I've read that the 30s can't really handle the power but if its working for you guys it gives me hope and brings my cost back down to "Wife Approved"![]()
I just checked ebay they have complete kits with the belt for like $100 and up. Probably aftermarket but might be ok. Maybe someone elase on here has use one of these complete kits before, and can tell you how it did for them.but yeah i guess you can get something around $150. The kit should have everything including the plates
Cole
Most torque converters are rated pretty conservatively for HP ratings. You should be fine.
I would be way of putting a comet 30 sure on that engine. It is not meant for it. You might not blow the clutch, but you will go through belts at a rapid rate
So even with the 1" with the 8 - 13 HP rating its still a no go?
And another question could I use the 1" on a smaller engine? a 6.5 HP for example.
This is one like im talking about. And click on the description it has the specs on it also.
Cole
http://m.ebay.com/itm/331178977925
Yeah you will need the driver and the driven to work together. You can build a shield for it. If you have the tools to do it anyway.
Cole
