tecumseh engine - thoughts?
colestreasures
Kentucky
I just checked ebay they have complete kits with the belt for like $100 and up. Probably aftermarket but might be ok. Maybe someone elase on here has use one of these complete kits before, and can tell you how it did for them.:thumbsup: but yeah i guess you can get something around $150. The kit should have everything including the plates
Cole
colestreasures
Kentucky
What did you search? I can only find 30 series, wouldn't that be to weak to handle the 13hp?
A 1 inch bore should handle from a 8hp up to a 18hp ,i have one on a 16hp and a 13hp engine and it works great, its a 40 series IIRC. My neighbor has one on his 3 wheel kart with a 13hp and it does good. When you look check the specs on it , it should tell you what engines its made for.:thumbsup:
Cole
Kansas City, Kansas
A 1 inch bore should handle from a 8hp up to a 18hp ,i have one on a 16hp and a 13hp engine and it works great. My neighbor has one on his 3 wheel kart with a 13hp and it does good. When you look check the specs on it , it should tell you what engines its made for.:thumbsup:
Cole
Could you link what you have found?
The 1" I am finding are all rated only 8 - 13 HP which worries me being at the edge of that scale. I've read that the 30s can't really handle the power but if its working for you guys it gives me hope and brings my cost back down to "Wife Approved" :lolgoku:
colestreasures
Kentucky
I'm at work niw but when i get the chance ill pist a link, or maybe someone else will see this and do it . And they might also know if you really need one of the other series T/C .
Cole
soggycrashed
Honolulu
Cole
We're these 1" or 3/4"? The only torque converters I've seen on eBay for $100 were 3/4" and could only handle 8hp max.
soggycrashed
Honolulu
Most torque converters are rated pretty conservatively for HP ratings. You should be fine.
Kansas City, Kansas
I would be way of putting a comet 30 sure on that engine. It is not meant for it. You might not blow the clutch, but you will go through belts at a rapid rate
So even with the 1" with the 8 - 13 HP rating its still a no go?
And another question could I use the 1" on a smaller engine? a 6.5 HP for example.
colestreasures
Kentucky
No the 6.5hp is a 3/4 shaft. And let me clarify this i didnt say i was running a 30 on mine i am running the 40 series on mine. I was just saying you can get a 30 series 1 inch shaft rated for you engine, and if its rated for up to a 13hp then it should carry it.JMO and yes the 30 is a weaker setup , what series was the one you found rated from 8hp up to 13hp?
Cole
Kansas City, Kansas
This is one like im talking about. And click on the description it has the specs on it also.
Cole
http://m.ebay.com/itm/331178977925
yeah I'm pretty sure its a 30 series clone. I linked
And what you linked, don't I need the other half? This is the problem I'm hitting with the 40 series its all in separate pieces. Plus not having a pretty back plate and cover really bugs me for no reason:lolgoku:
Thanks for the follow up Cole,
Hippie
Kansas City, Kansas
Yeah you will need the driver and the driven to work together. You can build a shield for it. If you have the tools to do it anyway.
Cole
Got it okay. Its all coming together now. I can't thank you enough for your patience! I'm going to check my local shop her in a few hours when they open. (I need to sleep more:oops:)
If I do get this 4200cc on Monday I'll just up more info, maybe start a build thread because I'm almost ready to start!
