zzirrgrizz
- Messages
- 35
- Reaction score
- 0
Hey everyone, so I know there has been a little bit of talk about putting a turbo on a Briggs. However, most of these discussions never got to a conclusive answer so I figured why not try to get to the bottom of this.
Here's my simple theory on how it should work (I know there are probably a lot more factors, which I hope you guys could mention to me)
You have your turbo mounted a little distance away from your motor, have a piece of tubing run from your exhaust to the inlet that spins the turbine wheel and on the business side of the things you have a piece of tubing running from your compressor wheel's outlet straight into your carb.
Is this a possibility? I know it's easier said than done (there would need to be some form of lubrication for the turbo being pumped through) but I just want to get the jist of things here.
Could you possibly put a turbo like this on one? It's pretty small
http://www.ebay.com/itm/GT15-T15-Tu...Parts_Accessories&hash=item3f0f6b7cb7&vxp=mtr
