push button start
MoWaterfowl
I have a gx270 QAE (electric start) and I'm trying to find a wiring diagram of some sort to remove the ignition switch and replace it with a push button remote start. I found a kawasaki wave runner start/stop mount I want to use. The wiring coming off of it is simple enough.
The start button is just a momentary switch and the kill switch is always open with an emergency tether. Nothing complicated. What I need to know is where do they need to connect?
Thanks in advance.
-- MoWaterfowl
KartFab
One goes to the starter solenoid
The other goes to the battery
Switch goes in the middle
That's how to jump start it. I don't know if that's the correct way to do it though.
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
I had same principle for start and kill switch.
So plus from battery to push button, from it to plus on starter. Minus starter to battery minus.
Kill switch, I cut plus from batery to cdi and put switch there.
I had a 1970 Chevy that for some reason lost the "continuous" power part of the ignition switch.....so I ran an alternative wire to the coil....and hooked it to a toggle switch under the dash.....now.....my vehicle was nearly theft proof...and .....seemed to break down a lot on dates.....:cheers2::cornut:
