When I purchased a shifter kart rolling chassis a little over a year ago, I realised it wouldn't fit in my 7'x4' box trailer &, my AusEx had less chance because it was even wider so, I started looking fo a suitable trailer & eventually found a small boat trailer with a flat frame (see pics 1 & 2); width = 4', length to peak = 8'6"; when finished, the base will be 4'2"x8' & total length will be 10'6"...
After almost a year, I finally started the necessary mods to turn it into a usable kart trailer which will have the capacity to carry up to 2 karts; apart from the 2" x 2" draw bar, the entire frame is constructed using 1" x 2" SHS, making it really simple to modify...
The first thing I needed to do was establish a rectangle base so, wheel arches off, a trip to the local steel merchant & add a 1" x 2" straight rail down each side... that's when I ran into my first problem...
On the left side, there was around 5/8" clearance between the tyre & the new rail; on the right, there was around 7/8" clearance between the tyre & the original rail...
If I simply move the axle across, I would end up with around 1/4" clearance one each side... not enough for my liking...
I considered stretching the axle in the centre but, once I realised there was a small spring locator plate welded to the axle & that the stub axles weren't straight, I decided to bite the bullet & replace the entire axle, using the original stubs...
Coincidently, I just happen to have a length of pipe exactly the right size...sitting right next to the trailer (that's where it was "stored")
After cutting the stubs from the axle tube, leaving a small length as a base point, I squared off the ends on the lathe, cut one end of the tube square & welded the two together...
Now to trial fit, measure, cut & weld the other end...
