Relativity
Any guess on how much HP, and TRQ this engine is making. Listed are some specs below:
Harbor Freight 212cc (non hemi)
-ARC Billet Flywheel w/4 degree advance in timing
-RuiXing Carburetor w/140 emulsion tube and .037 jet.
-High Flow Air Filter Adapter and Angled Air Filter
-MOD2 Grind, Predator Core Dyno Cams
-ARC +.020 3.328 Billet Rod
-210FA PISTON Assembly (hemi piston)
-.010" Predator 212 Head Gasket
-Head, Racing, GX160/GX200 Honda
18cc (UT2 Casting)Springs:22lb Valve Size & Type:27mm Intake, 24mm Exhaust, Stainless
-DJ-1100 Ratio Rocker 1.3 ratio
-Autolite AR3910X Racing Spark Plug
-AKRA/WKA Box Stock Header & Muffler Kit
I have heard anywhere from 10HP-15HP @ 20 ft/lb of peak torque.
My own best guess is 12.5 horses and 15 ft/lb!
