I cooked my Predator :(
Bosch
Lincoln, NE
I was out pulling the boys around in the snow with sleds behind the Murray, and the Predator 212 suddenly ground to a halt with a nasty screech. And it won't pull/turn over. It's toast. :(
The thing is, it still has oil in it, and as best as i can tell more than a little. :ack2:
Good thing those motors are cheap..
BirdFanatic
Jonesboro Arkansas
Do not throw it away it could be the clutch i had one seize up on my i couldnt pull the starter or get it to turn over when i lifted up the back of the kart and pulled the starter it started
lyfesaver
Dallas, Texas
But you are right Bosch, those motors are cheap. So it is not going tot set you back TOO much. 50-75 for used even. I did do some research and found the Predator 302cc seems to be a bit more reliable, even tho the Predator line is pretty reliable for its price already.
Axx3d
MN
Im about to pull the pin on a few of these.. would also like to know the fail point if you decide to crack it open..
Xtreme Yard Karts
Sweet Home Alabama!
Unfortunately, this happens from time to time with all engines. A friend of mine bought a brand new Briggs Raptor years ago and it lasted about 2 days after break in. The rod broke and knocked a hole in the block. It sucks either way, but at least you're only out $100 instead of $400! :cheers2:
I would also like to know what failed, as I'm considering buying one of these as well...
Bosch
Lincoln, NE
It'll be a month or better before I get into it. It's single-digit temps now for the year and my shop is poorly heated.
Bosch
Lincoln, NE
I measured tonight, and it's too wide to go through the sliding glass door in the basement....
:rolleyes:
for whatever it's worth, I have every intention of replacing with the same predator 212.
adsum
New York
:rolleyes:
Pop the motor off, and crack open that case! :useless::roflol:
Axx3d
MN
The motor is too wide to fit through a screen door?
Man you got some skinny screen doors Nebraska ;)
It's 17 degrees! I will let you all know when I learn more.
Well.....let me help....screen doors are generally 30-36" wide Predator engines about 18"......
17° Is cold.....it's 15° below freezing.....
Now.....you know more..........................:lolgoku:
I can't say too much .....I'm in Texas....it was 24° last night.....I had to put on a ski mask to look out the window......lol....
Bosch
Lincoln, NE
Ok, people.. I will try to remove the motor over Thanksgiving break, if you can all keep yer pants on until then..
