GX390 Questions
MancoGX390
Just tinkering...
Devon, England
There is no max RPM of a comet 40 series that I know of. With that said, the engagement rpm can be between 1600 to 3100 rpm. What I take that to mean is that the drive unit will engage at the lowest rpm of 1600, and with a heavier spring set up, it will begin to engage at 3100 rpm. 40 Series are pretty heavy duty.
Although I cannot say for sure what the max rpm is, I could venture to say that it is possibly much higher than what your 4 stroke engine could feasibly achieve. (In other words, who knows?!)
http://www.hoffcocomet.com/EpiphanyWeb/flexpage.aspx?ID=75
You need to rejet that carb. It's way too rich and you're leaving power on the table. If you do remove the governor and want to install a new rod it is not difficult at all as because gx series engines have timing marks on the cam and crank. You can't really mess it up. Honestly you don't even have to remove the piston to install the new rod. You'd undue the circlip nearest you, unbolt the con rod cap, slide the wrist pin out and just reinstall the new rod.
Yeah I know i have to get the new rod and flywheel what I'm asking is would removing the governor be worth it for the extra RPMs bearing in mind a new rod and flywheel cost about £230? Would i gain any more speed? Also Tkart, with the new air kit I've got its not running rich any more, plug is a light burnt brown.
tazmannusa
Yettem, California
Couple ways to do it,adding the flywheel, rod and removing Governor and leaving your gearing the same would just add to the top end speed , check out one of the speed gearing calculators online . Lower your gearing to where at 5k rpm your top speed is just a little faster than at 3600 rpm with the gearing you have now and you will gain a lot from low end on up, Just depends on what you want. If it was me and I was swapping flywheel and rod I would defiantly go to a little heavier valve spring, floating valves can be bad IE piston slaps the valve closed usually does not end with good outcome
Tom
KartFab
Valve float on OHV engines could ruin your engine as tazmannusa points out. On the old briggs and other engines that are not OHV, it doesnt really matter.
You already have enough torque (ive seen that donut video) I have no idea what your max rpm would be in the end, but if you keep it all the same and assume 5500 rpm your lookin at 60 mph.... Which is just way too fast I think. Then you have to look at tire ratings for speed. Yours are probably "non-highway use". Then what if you hit a bump going 60 mph? There's no shocks so you could fly off and get hurt, or worse, flip over and be strapped in and die (I remember seeing a harness on your kart).
I'm all for driving crazy and fast, but 60 mph is just too much of a risk off road. If you were on the highway, that would be feasible but still stupid since the tires are not rated for that kind of speed. Just my pre-frontal cortex kicking in.
Is 40 mph not fast enough for you?
MancoGX390
Just tinkering...
Devon, England
40 is fast enough i was only wondering, seems a bit expensive though. Thanks
KartFab
Forgot to ask is your 390 one of the newer models? If it is there is a rev limit in the coil of 4k
Which ones have the limiter?
I didn't mean to sound harsh, just don't want you to die or get hurt. Not that you would, but its always good to step back and see the risks associated with a kart that wasn't meant to go that fast.
MancoGX390
Just tinkering...
Devon, England
Yeah i worded that a bit bad, i wasn't trying to be rude or sarcastic, i get what ya mean and understand it and with how rough my field is, i dont think going faster is a wise idea! Thanks for your help again Grant!
