MancoGX390
Just tinkering...
There is no max RPM of a comet 40 series that I know of. With that said, the engagement rpm can be between 1600 to 3100 rpm. What I take that to mean is that the drive unit will engage at the lowest rpm of 1600, and with a heavier spring set up, it will begin to engage at 3100 rpm. 40 Series are pretty heavy duty.
Although I cannot say for sure what the max rpm is, I could venture to say that it is possibly much higher than what your 4 stroke engine could feasibly achieve. (In other words, who knows?!)
http://www.hoffcocomet.com/EpiphanyWeb/flexpage.aspx?ID=75
You need to rejet that carb. It's way too rich and you're leaving power on the table. If you do remove the governor and want to install a new rod it is not difficult at all as because gx series engines have timing marks on the cam and crank. You can't really mess it up. Honestly you don't even have to remove the piston to install the new rod. You'd undue the circlip nearest you, unbolt the con rod cap, slide the wrist pin out and just reinstall the new rod.
Yeah I know i have to get the new rod and flywheel what I'm asking is would removing the governor be worth it for the extra RPMs bearing in mind a new rod and flywheel cost about £230? Would i gain any more speed? Also Tkart, with the new air kit I've got its not running rich any more, plug is a light burnt brown.
