New to building & my first build
Yamaha440SSKart
Edmonton, Alberta, Canada
I am in the process of building a kart using a sled engine, a Yamaha 440ss to be exact, I have the orginal primary, seconday, carb, and exhaust, I have the whole sled to be accurate. From my understanding a lot of people have used sled engines in their builds, my thought was to run a 20t drive coming off of the secondaries drive shaft and a 37t driven on the live axel, my plans are to use 1x1x0.125 cold rolled square tubular steel. using a basic box design, I have no plans, but yet I do have a plan to build on the go. if anyone has any pointers or guidance anything and everything would be appreciated, also would a chop saw be recommended for making the angles or should I be using a steel band saw? also im thinking of doing a stiff frame(suspensionless)
Yamaha440SSKart
after further looking around and research I found a design I liked and will be pursuing, i'll be going with an arachnid build lol, I know is common lol but looks like a sweet ride and im hoping can handle the engine, any input as far as that engine size with that cart is welcome
Jeeze!!!! Another Canadian......:ack2:....
Well......welcome to the forum. .....I guess......:rolleyes::lolgoku:
It's just a little joke we have around here....you'll see
So.....Welcome to the forum! !!!!!
Yamaha440SSKart
yeah another Canadian I guess lol, but a go kart lover none the less lol, but what if I just moved to the states lol? and it said I was from the states lol difference I think not lol consider it more as a neighbor lol
Don't panic about the Canadian thing, it's an inside joke around here, you'll catch on soon enough :thumbsup:
That sounds very steep to me, that's less than 2:1; we usually recomment somewhere in the neighbourhood of 6:1
It's better to use large, thin wall tube than small, thick wall tube; using 1" thick wall tube, you'll end up with an very rigid & heave pig of a frame; 1.5"x0.085" is as strong or stronger, with a little more flex (with a rigid frame, you want a bit of flex...)
-Build around the engine
-don't be afraid to expand a little
-please include some type of roll bar or cage...
You will end up with stronger, more accurate joins if you simply notch the tube, ie: cut out a wedge & leave one side intact; whether you use a bandsaw, grinder, hacksaw or a blunt knife is up to you but, it's extremely difficult to achieve this with a drop saw...
Remember that, when cutting angles, you need to measure half the angle from the square line; for instance, if you want a 60° angle, mark a line square across the tube, then mark 30° on each side of the square line...
Yamaha440SSKart
I did some reading on that but I was curious to that seeing as how im using a sled primary and seconday prior to the sprocket ratio, or please do correct me should I use a 6:1 and allow the sled drive to get closer to that 2:1 ratio?
I will be using 1"x1"x0.065 square tubular steel, I did get plans for the arachnid and it said to use 1-1/4 and 1"
I will most definitely be doing that and more then likely a harness lol and skid plates etc... once it's all said and built
Dude, a fellow Canuckistani here. Don't let the Texan bunch rub ya. They're all good bunch of guys, I say this as there is a good amount of them here.
Poboy just has a way of testing the newbie peeps, see how thick a skin and how good a retort they have back.
He's all good.
I'm not saying you should use 6:1 but, 1.85:1 is never gonna work...
Compare the size of the sled drive wheel to the size of the wheels you intend to use; if the wheels are (let's say) 3 times the size of the sled drive wheel, the axle sprocket needs to be 3 times the size of the sleds driven sprocket to compensate...
That's fine when using a low powered industrial, gy6 or pitbike engine but, a 440cc sled engine isn't exactly "low powered"; to compensate for the extra power, you need extra steel but, whatever, it's your funeral...
Rule of thumb is if there is roll protection in use there should be a restraint; if it's a flat kart, there should be no restraints... :thumbsup:
Yamaha440SSKart
Lol exactly why im asking. First build so the more info I can get the better, what about using a rectangular tube what would be your thoughts on that? or even bumping up their 1" tube to 1-1/4 and the 1-1/14 to 1-1/2?
What would be thought of having a casing around the chain(chain case) and having a lubricant inside said case?(ATF fluid,gear oil, etc)
Yamaha440SSKart
got a new quote and I went with 1.5 and 1.25, will be adding additional support with what I have for extra.
Also after research I decided to do as recommended and go with a 6:1 ratio, may change to a 5:1 later on if I feel the need to, with also be going with #41 sprockets and 420 chain
That's a bit of an "either/or" situation, both have pro's & cons so, it would be a matter of making the list to see if it's viable...
I'm loath to say yes or no on this because, IMO, it's not a bad idea but, it's not necessarily a good one either...
Does that help? :lolgoku:
Yamaha440SSKart
lol yeah, kinda like a yellow light, either you punch it and make it before its red and risk getting a ticket lol or wait for the next green and it's to late lol I have read up a lot of other people doing the arachnid build and having issues with the hinges if you would lol? I am thinking about scrapping those and using the angle steel to create those parts and will be able to properly align using a drill press?
Yamaha440SSKart
I understand that lol, but here's my thought though, it is an older sled, meaning it was like 80% steel lol, like I know the skid out of it is heavier then **** lol, not to mention the track weight, and the engine frame lol, im thinking I may be close to the same weight. If the Yamaha engineers for that sled thought that it'd be a good ratio then im thinking it should be good here to? of course gearing a lil bit lower so maybe to a 2.5?
