Cart not running - could use help.
firemanjim
Just kartin' around....
Houston Texas
I thought the idea was to boil the carb in lemon juice :huh:
I add no heat.... Others might/do, but in reality, the acidic level is high enough to do the job. I see no reason whatsoever, to add heat.... Coincidentally, when soaking in lemon juice, the crap/crud kinda makes a few bubbles on the surface, not rapidly, but enough to make froth.... Like when you boil potatoes.....
copperdog
junior engineer
lakeville mn
From what it sounds like you need new points and condenser. I work with older Briggs engines but there should be points right behind your flywheel. If you get it off there should be a wire going into a cover take that off and get some new points and condenser.
4rcFed
Ummmmm....which one????? Because...I'm not a big fan of boiling. .... (affects the taste)......but I've found if you want to speed up the process. ...thd addition of alcohol can help. .....:lolgoku:
I want to give the non-boiling attempt a try.
I have an oven/stove for garage use out there, but it is buried at the moment. Plus I would need to find a pot....so we'll give the other approach a try.
Ok....just to clarify. ...the alcohol only helps if you're going to drink it.....doesn't help with the carb. ....although denatured alcohol might.....but then again. ....maybe better to do one thing at a time. ...
It could be a good thing. ...but I haven't tried it. ...it could also decrease the efficiency of the lemon juice. .....
firemanjim
Houston Texas
Decrease the efficiency of the acid? I never have a problem just letting it soak in juice over night... (8-16 hours....)
Adding heat, helps break down and soften dried crud from the fuel. With a little more time, so does the acid, alone. Adding heat also intensifies the pungent odor..... :ack2:
