Aussie kart "It doesn't have to be perfect"
rubberducky
Kart proj underway
Australia
Sitting around the table post christmas festivities we realised (brother-in law and i... that we needed a project... something substantial. In our favour access to my parents 40 acre property to which there is plently of room for some off road action.
It was decided we need something motorised... something cheap... something fun... and something that can handle off road!
The project begins.. an offroad kart was the calling.
It began with the purchase of an engine. A 5.5hp horizontal shaft engine from deals direct ~ $179. AU
We quickly mocked up a basic frame with the stick welder and sat the engine on for a test visual, with some trolly wheels we had.
We decided the running gear for this kart would be above us to manufacture so we shelled out for: bearings, sprocket (64 tooth), sprocket hub, chain, and a centrifugal clutch(12 tooth).
Then we test fitted a centrifugal clutch to the engine shaft ..... shaft was 2mm too big to fit in the clutch ..wtf. Easily fixed we took it to a kart dealer and had it machined to fit. Nice and snug now.
While the shaft was out we decided it was time to take the govenor out as well.
We also decided to cut the low oil sensor line but have decided to leave it in at this stage until we get more confident about our mods :p
There will be more pictures to come. :)
We have done a few changes to the main chassis and will take some pics of that soon.
But so you know this is an offroad kart so there will be full independant front suspension (of sorts) and rear suspenion to suit.
For now :)
jr dragster T
Cold place
The governer limits the maximum RPM the engine can run at. Most utility engine's are rated at 3600 + - 100 RPM or so.
jr dragster T
Cold place
Lol I wasnt saying anything bad about it. Lol you could like plasti-weld over the lobes and sand it and make a new cam pretty easily.
jr dragster T
Cold place
So if you where to put a steel inplace of the nylon cam would you need new tappet's? Like are the tappet's desihned only for plastic to metel?
Russ2251
AZUSA:Powered by LAWN-BOY
Unknown to me. Probably no different as tappets still have to rap into valve stems. If softer, would mushroom in short order.
rubberducky
Kart proj underway
Australia
Front Suspension arrangement
Hey guys, just put together a front suspension arrangement. Managed to get away with some shocks off a mountain bike we found in a skip bin. They have adjustable knobs on the top which will help us set the resistance in testing. The other key was to use some ball joints on the bottom triangle arm... we went a triangle so it can resist horizantal impact as it occurs.
It seems to work pretty well.. we may need to brace it up a little more for some strength..
You can also see that we are starting to think a little bit about how our steering will fit in.... and we found an old school chair which will be welded into place soon...
Next on the kart build agenda will be some steering spindles and tie rods and maybe even attaching the front wheels!
modelengineer
Lord of the noise
Sydney, Australia
Looks good, but you should join the top of those shock towers for strength. Just where the top of the shocks are, join with a piece of pipe/tube.
Keep up the good work,
Andrew (in Sydney)
rubberducky
Kart proj underway
Australia
Yeah.. we definately join at the top.. did a little bit of load testing tonight and i can see some movement.. also might brace down to the front of the frame...
Kaptain Krunch
Pro Junk Collector
vermont
nice use of old bike's, but will those shocks be able to handle the weight of a go kart? I've bottomed out my bike shocks plenty of times going maybe 30 or 40 and hitting some rocks or ruts.
rubberducky
Kart proj underway
Australia
Good question Krunch... as you can see tht we have naturally say the triangles at a lower position than the main frame... such that a bottom out of the shocks will mean the triangles will be horizontal...
