Brakes
thaipham25
texas
Its pretty obvious why, i figured out the problem. How old are you guys like 5-10. You guy like to bully people. Get a life. I got better thing to do than fight on line with lil kids.
Sent from my LGL35G using Tapatalk 2
Ok ok, everybody settle down...
Here's my observations:
1. you need to secure the cable sheath correctly
2. you need to secure the inner cable to the actuation bracket correctly
3. I feel the pads are worn uneven because the caliper is mounted uneven; replacing the pads will only repeat the problem...
Here's my opinion on how to solve the problem in it's entirity:
Replace with a hydraulic setup, a BIG one!
You may still need a rod or cable to actuate the master as you probably won't find a kit with a long enough hose to reach from front to back of the kart...
thaipham25
texas
Thankyou fab. I tighten the mounting brackets already when i found the pads. If pads don't work I'm going with your advise with hydro but big ones like you said but one that comes with 3 calipers
thaipham25
texas
I measured the calipers to see if it was 90° and it is. I also put 2 bolt inbetween the bracket and brakes to help tighten it
I also install cable clamps.
I also bought some brake pads at a local go cart store and trashed the old ones. The cart now stops on a dime. Going 70mph it does take a block to stop it though. There is only one small problem with the brakes that i notice. The pads doesn't move side to side when brakes are not engage it slightly squeaks. Is it the incorrect pads for the brakes? Do i need to have it slanted slightly to the left side so gravity can do its job?
thaipham25
texas
and would this be consider a buggy or cart. Can it ve street legal in texas
firemanjim
Just kartin' around....
Houston Texas
Not like that..... If you wanted it to be street legal, you should have said something from the beginning.... You will have to replace probably 40% of what you got, to make it street legal...... And I'm not arguing about how and why....... :surrender:
ML-TOYS
long island, new york
With a kart like that i would trash those brakes right away and get hydraulic ones, as in dual disk rear. You can even keep that original caliper right there with a handle next to your seat like the manco parking brake. Then mount hydraulic caliper to the rear od disk. Now you will have real brakes with an emergency/parking brake.
Better than getting killed due to having faith in basically a bicycle cable to stop you without stretching or breaking at 70mph.
Axx3d
MN
I dont know the classification of it nor the legalities of it for street.At those speeds, If not already id throw a 5 pt harness and make helmets a must.
I do however think it looks like an awesome ride!!
Id be throwing some 22" knobby tires on that rig.
Glad u got the brakes resolved buddy..
thaipham25
texas
Ml that's a great idea. I really don't wanna waste the brake so yep E brake it is
firemanjim
Houston Texas
Good, you will need a mechanical brake as your e brake, here in Texas, as one of the things needed for street legality. I'll post a link to the tires you need in a minute. You would also have to have DOT approved high beam @65 watts and a low beam @55 watts. All lights must be DOT approved. Tires,seat belts, horn.... All the same stuff a car has to have.... And it must be DOT certified.
thaipham25
texas
Sounds easy enough. Hopefully motorcycle parts will easily modified on this cart.
Am I seeing this correctly... You put a bolt behind the caliper, in between the bracket???
If so, you will wear the brakes quicker than if you left it. These calipers are meant to float in the bracket.
So the cable jacket now still need to be secured, that's why for the main reason it has bad braking.
That cable still has nowhere near enough leverage on the arm. Cable pull must be ~90° to the actuating arm. The END of the cable sheath needs to be in a bracket to stop ALL sheath movement. The cable is connect to the arm in a location that reduces leverage- badly. Lastly, I would not consider that cable stout enough for a mechanical brake system.
Hydraulics, it is.
thaipham25
texas
Yeah i can't believe the brakes out of all things gave me the most trouble. And guys thanks for the advise about the anchor on the cable sheath but i have it anchored on the side but doesn't show on the pic. The cable is snugged tight
