thaipham25
Am I seeing this correctly... You put a bolt behind the caliper, in between the bracket???
If so, you will wear the brakes quicker than if you left it. These calipers are meant to float in the bracket.
So the cable jacket now still need to be secured, that's why for the main reason it has bad braking.
Really?? When bolt is off the pads, its grinding unevenly and warped. Idk I'm so confused which is the correct way. Oh well ima replace it anyways
Sent from my LGL35G using Tapatalk 2
