Brakes
thaipham25
texas
My brakes isn't able to stop my cart even going slow mph. When it does stop I'm at least been pressing the brake pedal for 1/4 mile going 25mph. What should i do. Add one more brake should help stop the cart or should i trade in for hydro. Its a six feet cart or. Mini dune buggy with 1-1/4" axle. Please help bc i tried adjust the brakes so many times even at a tight adjust and still. I really need help cause i almost got into accident twice but had to swirved into ditch instead and no way i can stop at stopsign. I always run them unwillingly
Sent from my LGL35G using Tapatalk 2
RiverSideRun
NJ
You most likely don't need another brake
If it's a band brake your connecting rod is most likely bent from pressing the brake to hard
thaipham25
texas
I have brake calipers for go cart on mini dune buggy. I can't take any pics now will have to wait til tomorrow.
thaipham25
texas
Scout
Nutjob
Indiana
Is that a cable operated caliper? If so, where is the bracket that holds the end of the cable sheath? What are the hose clamps for?
thaipham25
texas
The cable works fine. It pulls the bracket up and down. Its the pads i believe. I open them up and the pads had warped grids on them. So it only compress at and angled. I think i need new pads
thaipham25
texas
Fab its the same cart but even with all the hp it still won't stop at 25mph
No the sheath needs to be held in order to allow the cable to channel it's force on the actuating arm. You also need a better way of securing that cable end. Not with pipe clamps(jubilee clips).
Usually you use a clevis, and some cable jam nuts.
With the current system you have is, I'd almost say using rods from the caliper to a ways back on the machine, couple that with the cable there.
I believe many other buggies are like that.
Oh, if the pads are worn at an angle to the disc, the mounting bracket is bent(or not installed at a 90* to the disc), the caliper is being torqued by the cable setup(I doubt it as there is typically no rotational movement allowed in the bracket), or the disc is warped badly.
That's one rigged up mess.....new pads couldn't hurt anything. ....just as pics of what they look like wouldn't either.......
Don't discount the advice that the outer sheath needs to be clamped.....it sure as:censored: does!!!!!
Let's put it this way. ....go out to your car and put your finger on the brake pedal and push.......SEE????? ....it moves!!!!!!
Now. ....how well do you think you can stop your car with that finger?....
Nuff said........
thaipham25
texas
That's why i was thinking about hydrolic. It has its own brake line and calipers squeezes to stop the cart. I think you guys might be on to something with the cable. It seems tight and snugg but it isnt reliable bc it can losen up when lease expected. My cart is kinda rigged but I'm on a budget :eek::sly::sly:
thaipham25
texas
Russ it is on idle when gas is let off. The cart torque converter still spins the tire when on jacks but when its on the ground no movement at all
thaipham25
texas
:mad2::mad2::mad2::mad2::surrender:
The shelves never get empty do they guys??????? .....Why does this seem so familiar? ?????? First. ....they don't listen.....then they get mouthy....Poboy out.......:surrender::censored::smiley_omg:
Really omg its not the problem. If it was i wouldve fixed it. Its the pad. I just put the thing together and not taking it apart just for pics. Just take my word for it. Y would i lie cause i need it fixed. I'm not trying to be mean just sarcasm
I'm going to make an observation here- having ignored the not-so-family-friendly language, on a family-friendly site.
You presented a problem, and asked for help. You rejected the help that was offered, insisting you knew the solution. So... Why ask?
