What is this?
Paden87
Navarre, florida
I would like to know what this thing with two wires is that is on the bottom of my carb? And does it need to be hooked up or do I need a different carb.
Im not exactly sure, but I like the spent casings on floor of the truck.... what a pic :)
I think those motors were on a generator of sorts.
Paden87
Navarre, florida
I just found out what It was. its a magnetic fuel cut off switch thing of somesort. and yes those are spent 9mm and some .50 Beowulf in there somewhere
dsgreene71
I believe it is an "Anti-Backfire" fuel shut off solenoid. I have a similar module on the carburetor of my 17.5 hp Briggs&Stratton OHV (lawn tractor).
zbuck
Ft. Wayne, IN
:wai: That is a anti-backfire soleniod. When you turn the key to either run/start it retracts the plunger down so that the main jet gets fuel. When you shut off the equipment the plunger engages (goes up) to shut off the fuel supply to the main jet. As it only shuts off the main jet, and not the fuel supply to the bowl, fuel can still flood or seep into the crankcase if the needle valve/float is not working correctly. Put your hand on the soleniod and have some one turn the key to run, you should hear/feel a click.
firemanjim
Just kartin' around....
Houston Texas
:oops:
I stand corrected.... I just looked it up. Yes it IS an anti - backfire solenoid. My apologies to dsgreene....... :thumbsup:
As a kid, to me, it was just a fuel shut off. And I guess I never put much more thought into it than that......
