TC for my kart
RiverSideRun
NJ
I know that there is another right below mine but I need a little bit more detail.
I have a 5hp Briggs fun power and a klipper kart not sure the of the weight but I weigh about 140
I will mostly be doing off roading (dirt, turf, gravel)
What torque converter setup do I need
Leaning more toward acceleration
Any more info I need to give?
firemanjim
Just kartin' around....
Houston Texas
A standard comet 30series torque converter is all you need. Buy a kit, with the backplate, and it just all bolts on..... NO measuring or guessing what belt.... The backplate keeps the clutches lined up and spaced correctly..... :thumbsup:
firemanjim
Houston Texas
firemanjim
Houston Texas
I'll look around but I'll most likely go with the cheaper
On a budget
I think half-breeder has the china knock off, and hasn't had any complaints, as far as I know. You should PM him and get his opinion. He has done a ton of work on his kart, and runs it hard. :thumbsup:
Half-breeder
"Edit" button removed
I think half-breeder has the china knock off,...
*DINGDINGDING*... AND TODAYS WINNER OF THE MOST RACIST 'sounding' COMMENT... :roflol:
... and yes I 'do' have the knockoff. I cant 'compare' it to an original Comet( seeing as that Ive never owned one)... but the 'only' thing that Ive noticed in a difference w/ the Comet is the knock off has a 3/16" key(integrated), and the Comet has a 1/4" key(integrated). The 1/16" off gives the knock off a very distinct 'noise'. To the untrained ear, upon start, an engine will have a 'clanging' sound, almost sounds like a rod about to be ejected... (the 'clanging' sound can be heard at min 1:34 real well...) Im planning on cutting a 3/16" keyway opposite side of the 1/4", on the drive shaft, to fix the 'noise'.
https://www.youtube.com/watch?v=VrkZo1ehC80&list=UU9tLeV67lsEIrulgHA6t0wg
... other than that noise(which can only be heard at idle). I personally dont know of any difference in the 2(other than the $$$).
carter
So then the Key that fit's the TC has about 1/16 of play on the axle? Do you suppose that with more power to speak of, and going from hard braking to full gas repeatedly, might cause the key to shear?
Half-breeder
Nope, not at all(and its not on the axle... its on the engine's drive shaft)... If a TC made accelerating an instantaneous action(like a cent clutch), then it may become an issue... but seeing as that a TC starts off at such a low ratio, it compensates for the initial 'jerking' of the wheels upon takeoff, to a more 'smoother' acceleration(like a golf cart), but if you WoT it does tend to break traction. I run a Honda gx200(clone originator) that boasts around 10-11hp(stock only 6hp)...
They have springs that engage the TC clutch at a higher rpm. If used/gotten, then there 'could' become an issue w/ the key gap 'possibly' sheering, however doubtful. By doing so is ONLY beneficial if the engine has more power at higher rpms(normally the engines w/ a cam installed), such as for drag karts.
Also 2 additional features about the TAV2, vs most any other TC, is you have an OverDrive on it that will increase your top speed an additional 10% more than what calculations will equate(unless your engine wont push the weight at the OverDrive rpm speed), and it 'actually' has 3 different settings, on the driven, for the 'terrain' of driving, which is handy if you dont feel like upgrading to a 40 series later on, if by chance you happen to drive from street to hilly off road.
