first kart!
r_chez_08
Should be in the shop...
Cornwall, UK
i am starting my first cart (finally) this weekend.
it is going to be 55 by 140cms and will look something like gokart gurus red kart with a 6.5hp honda clone, 10"wheels and 16/70 gear ratio. ill post when make progress
r_chez_08
Cornwall, UK
i wish!!!! no its the clone of the gx200. it might be on the red kart. the only rhing i am stealing from it is the side thingys
r_chez_08
Cornwall, UK
lol, i have already started, i meant to say, ill post some pics at the wkend, but ill post them now, as :useless:
my wheel, frame, dads welds and steering. sorry the quality is so bad, my cameraphone is only 2mp
fluxcored
I'm so jealous - been trying to start since Sept/Oct 2008 just have a lot to do at this stage.
One final project to get out of the garage/workshop then I'm ready.
Keep the pics coming.
r_chez_08
Cornwall, UK
will do. i started planning last summer hols
r_chez_08
Cornwall, UK
here are some random pics of what it should look like
BradenM
Etre Et Durer.
In a big jar of Nutella, nom nom nom
Everybody dopes it differently; are you running your motor governed? I found it easier to set up a linkage without the gov, but it's personal preference. I took the stock air filter and box off, and ran a tube to the air filter in a different location. The space left over on the black plastic that the stock filter rests on was then taken up by a bowden cable housing (bicycle brake cable) and araldited in. I then screwed an eye hook (which was spring loaded to shoot back to idle) into the butterfly and ran the cable through the hole, then through the cable housing. This ran to a the top of a spring loaded lever, which doubles cable pull from the pedal. The bottom half of the lever has a cable that then goes to the top of my accelerator pedal. If you need pics, pics I can provide.
BradenM
Etre Et Durer.
I r ghetto.
brendonv
Australia, Perth
thats one low ratio. Its like 4.4:1! U are going to have great top end but i dont no about acceleration. O well, wait n see. Nice kart btw! Keep it up.
r_chez_08
Cornwall, UK
thanks for the great pics, they will help
what gearing yould you reccomend. i have to have a 16t #219 clutch though. also, how big would an 80t #219 sprocket be?
robin
in a house
i would use a jack shaft then run 35 or 40 pitch chain to the Axel
small pitch chain is harder to get lined up right and has to be tighter not to fall off
r_chez_08
Cornwall, UK
thanks, but i dont want to get too complicated, as it is my first kart, and as i said i can only get a 16t #219 clutch for my 20mm shaft and No i am not tuning down, knowing me i will mess it up
