predator 212 air filter adapter
firemanjim
Just kartin' around....
Houston Texas
You know what? I think you can.... Seems like I saw a thread where some one used an end cap, drilled it for bolts and through hole.....
Gonna do a quick search.....
I faintly recollect a few years ago, someone here made an air cleaner out of a tuna can, some foam, and a piece of metal door screen I think it was.
Depending on the sturdiness of the can, maybe a piece of flat stock inside if needed, I'd just leave it as is.
2SlickNick
American Minibikes @ FB
Mesa, AZ.
I need an adapter since I am putting a clone carb on my 5 Hp briggs Flattie, like Gran_Penn's Bronda engine.l
:oops: I missed the word "adaptor" for some reason (not having a good week...)
Sure you can, as long as the cap fits inside the filter neck, then it's a simple matter of drilling three holes (one for the carb throat, 2 for mounting) in the appropriate positions...
2SlickNick
Mesa, AZ.
Good find. Never too late....
I actually did make one. I used a flat end cap.
Badot
I'm running a super high tech 3/4" OSB air filter adapter. If you have the right size hole saws I imagine you could make one in about 30 seconds.
OSB/MDF/(insert any other abbreviated wooden material) will work for a short bit, until the gasoline starts to dissolve the glues/resins and it will disintegrate.
The cap idea is a pretty good idea though.
2SlickNick
Mesa, AZ.
Sorry it took so long for a response.
I just made another air filter adapter.
It literally takes 5 minutes.
I made it for a Briggs 6hp Intek, it fits the bmi air filters they sell, and cost me $1.99.
I used a flat and black PVC end cap (I think they are for septic or something like that).
It measures:
2" ID
2.25" OD
1" tall
I just traced a gasket on it and drilled a 1" hole and two 3/16 or 5/16 holes ( i can't remember size ).
Good luck...
midwesthunter
Rose Hill KS
I did the same on mine, used the black (ABS) pipe cap. need to grab a filter for it still. I took the original filter foam and ziptied it to the end cap.
