mgravley
Glad to find you guys.  I'm on about week 6 of trying to make a Yerfdog funcart run.  Got 3 small kids and I am determined to get it going.  I had no prior knowledge of small engines or drive trains but hey, learning keeps us young, right?  And is a little cheaper....
After messing with the original Tecumseh OHH65 for about a month -- cleaning then replacing the carb and giving it a valve job (a couple of times) only to have the original issue of gas shooting out the carb's air intake with every crank, I decided for time's sake I'd purchase the good old HF 212CC Predator and all would be good. (I'm still determined to get that Tecumseh running though).
So it is still sitting in the garage but I'm learning at every step. I now know what an assymetrical cogged belt is and what it fits on and what a Comet Torq A Verter is and what a driver and driven are.
So I just ordered a 1 1/2" longer belt, hoping that will do the trick, except that I also need about a 1/2" spacer for the driver to line up with the driven, and have to do a little work to get the throttle cable working right and have to figure out where the kill switch should connect on this Predator.
And if I can keep air in the tires, I should be able to get them in the wind by Christmas!! But I am really enjoying it. Mostly. If I had a welder I'd be dangerous.
