40 series TC rotation (driven)
rockman96
SC
After doing some searching and reading, I'm still unclear on this... Can the 40 series TC driven work mounted in either direction? By this I mean being mounted with the spring inboard or outboard.
I see pics of the 20 and 30 series with the spring mounted outboard, but all of the 40 series installations I've seen have shown them inboard. I don't have this option due to clearance issues.
So, will this configuration work ok?
http://i50.photobucket.com/albums/f310/DaveH2/Go Kart/TC_Drive_zps4aace9ca.jpg
rockman96
SC
Btw, how much preload is on that spring... is it going to try to fly apart violently when I remove the snap ring, or is it like just a half turn or something?
qtband
St. Louis, MO
Just be aware that the tension is there. When you install the new spring you'll put the tension in the opposite direction.
