Hey guys, I just ordered a 198cc Chinese go kart.
Pretty sure it's a honda clone of the 6.5 hp.
Anyway it's right out of the box, and this thing is running so rich! It stalls after an open throttle, and looking at the spark plug it is completely black! It doesn't come with any sort of instructions so I'm struggling to get her running properly. There is an assembly below the fuel tank with a governing screw which I am to assume is some sort of fuel pump. Winding her out completely still has the engine running rich. The fuel air mixture on the carb doesn't seem to do anything so maybe there is a blockage in transport.
The other thing is the centrifugal clutch smokes big time on take off. Surely that's not normal. It also engages to take off on idle so I doubt the clutch is working properly. The chain came really tight so I loosened off the engine from the chassis but still the drum is loose and has a bit of play in it. Is that normal? I tried to disassemble it but couldn't work out how to seize the shaft from turning whilst trying to unscrew the single retaining bolt of the clutch
If anyone has any help it would be greatly appreciated!!
