Chinese 198cc
Rustynutz
Hey guys, I just ordered a 198cc Chinese go kart.
Pretty sure it's a honda clone of the 6.5 hp.
Anyway it's right out of the box, and this thing is running so rich! It stalls after an open throttle, and looking at the spark plug it is completely black! It doesn't come with any sort of instructions so I'm struggling to get her running properly. There is an assembly below the fuel tank with a governing screw which I am to assume is some sort of fuel pump. Winding her out completely still has the engine running rich. The fuel air mixture on the carb doesn't seem to do anything so maybe there is a blockage in transport.
The other thing is the centrifugal clutch smokes big time on take off. Surely that's not normal. It also engages to take off on idle so I doubt the clutch is working properly. The chain came really tight so I loosened off the engine from the chassis but still the drum is loose and has a bit of play in it. Is that normal? I tried to disassemble it but couldn't work out how to seize the shaft from turning whilst trying to unscrew the single retaining bolt of the clutch
If anyone has any help it would be greatly appreciated!!
Welcome to the forum
The reason the clutch is smoking is probably because you are geared too high. Count the teeth on the clutch and axle sprocket and post here for us to see. The tight chain could have damages the clutch, and that is why the drum is loose.
What you are going to have to do is post pics of the engine and clutch here so that we can help you further
Rustynutz
Here she is. Don't mind the exhaust
Trying to remove the bolt on the clutch just turns the shaft. Behind the drum is a cog that I have tried to grip to prevent it from turning but with no luck!
??????????????? New one on me- you running a Ford 9 or something?
not too new.. 48T on the axle, and ten on the clutch..
But that's a <5:1 ratio for a 200cc clone... *shrugs*
Okay it came that way, but to me that sounds odd since we advice to start somewhere around 6:1 for such engine.
Could you provide pictures please?
that might help here
Ahh I know that kart.. Drifter ...something..
gas and brake (bike style) lever on a butterfly steering wheel, no?
that one:
isn't it?
Rustynutz
The site is struggling to let me upload the other images at the moment.
Trying to remove the clutch bolt just turns the shaft that second pic is a set of teeth behind the drum that I tried to clamp as I unscrewed the bolt but no joy
To unscrew the clutch bolt,
find a ring wrench in the correct size for the bolt, and place your thumb on the head and bolt to keep it in place,
hit the other end of the wrench with a hammer, that should provide enough inertia to remove the bolt ;)
Rustynutz
It's not reverse thread is it?
I set the air/fuel mixture the same as you would on any bike and she still stalls on take off. Is that a fuel feed under the tank that you can adjust how much the valve opens
Rustynutz
Your inertia trick worked a treat :)
The drum has some play in it. Should it be seated snug?
No- you have a carb issue....pprobably not an adjustable issue.... unless you consider float level.....
Edit: BTW- You have a rich condition-which means too much fuel. ...you should be trying to close screws and the only blockage problem you can have is AIR- not fuel......
The drum should have no lateral or radial play;
but of course it should clear the clutch shoes and spin free
while the engine isn't running ;)
[EDIT]
Ah wait..
what's your wheel size?
IIRC correctly there are two options small and big wheels ( 5" and 6" rims I think)
the main difference between the two are NOT the wheels size, but the fact,
that if the kart comes with bigger wheels you need a 2:1 wet clutch to run it.
So, if the chinese made a slight mistake (mounting the wrong wheelsize) you cannot get it to move without burning the cent clutch you need to either get the gear reduction box
(2:1 Honda wet clutch) or the smaller wheels...
But the easiest way to fix it -that is if your clutch is still usable- is to mount a #420 60Tooth sprocket to your axle.
Rustynutz
Yep it is the 6 inchers! I didn't get an option they just sent these however, there are two dipsticks so perhaps it is the wet clutch
Nope there are two dipsticks in the gx200 clone you have, your clutch is a 'normal' centrifugal clutch.
this is a wet clutch:
But I might have mistaken the size..
I'm not to sure maybe it was 6" rim small and 7" rim big... *shrugs*
check the actual wheel size (or read it from the tire)
is it 13" or 16"?
13" should work, 16" should not :D
Rustynutz
Just pulled apart the carby and put her back. Everything seems fine. Not sure why she's still running so rich
ODD...
looks like the snapring on the inside is missing (the one holding the sprocket to the drum)
or something worse :eek:,
I think you will have to take the clutch apart and inspect the parts;
get it off the engine and take pictures..
outside, inside, drum, shoes.. everything.
Sorry.
Okay, the drum should consist of four parts, two circlips (snapring) the sprocket and the drum itself.
Since I believe that is a MaxTorque SS chinese clone (as many others)
the clutch itself consists of 13 parts
the funny 'sprocket' you see on the back (wich has a tube protruding inside the clutch)
the back plate, six clutch shoes, one spring, a dust cover (front plate), another circlip and a fibre washer and in front of that a impregnated bushing...[that's 13 right?]
Wait.. maybe the bushing is missing??
If your clutch is NOT a max torque clone the above info is pretty much useless
(hence we need pictures ;))
PS Do not disassemble the actual clutch (where the shoes are) it's a PITA to put it back together
and most likely unnecessary
[EDIT]
after watching your video again, your chain is not properly aligned.
keep that in mind when you mount it back to your kart again.
