camaroman7d
Hey Guys, I have been lurking on the site for a while. I have read all the stickies that I think apply to me and still don't have the answer to my questions. Very cool site by the way with lots of good info, hopefully I will be able to add to it in the future.
I'm building a motorized "bar stool", basically a shorter narrower go kart with a higher center of gravity.
I am using a 13HP GX390 engine. I see there are several "extreme" duty centrif. clutches that are rated up to and above 13HP. This of course is the simple route. I have looked into TC's and I don't think they are my best option for this project. Limited space and more than what is needed for this project.
I will be removing the governor from the engine. What type of gear ratio should I be looking for? Just an all around fun gear, decent take-off and maybe 40mph top speeds. The "kart" will weigh ~150lbs and I'm 235lbs.
I also have an axle clutch with 8mm belt drive pulley, but I can't find any info on it at all. It came off the donor kart which was an old Invader lay down race kart. See pictures. Do any of you know anything about this? Would this hold up to the GX390? It is an 80 tooth pulley, I can order a 8mm pulley for the PTO as well. The kart had a small 2 stroke engine guessing 100cc, so I know it didn't have the torque of the Honda that I'm using. Would like to order my drive today ASAP so I can have this thing ready for a test run next week.
