Computerdewd.com?
bransen111
Southern California
Hey everyone, finally decided on a go kart as soon as I'm done building my welding table, and for being as new to this as I am I searched for the most detailed plans for go karts and how to put them together and found this kid, could you guys check it out and let me know if he's got good plans? Or if anyone knows better plans as detailed as this then let me know please, here's his website
**************.com
**************.com
All this website does is display searches, like ask.com. The plans that you are seeing are just links to other websites totally unrelated to the one you have posted.
Yeah, it works but, watching the vids, I found a lot of weak points; for instance, using the material he used, there's no strength in the rear axle mounts, nothing to prevent the tube from collapsing or even breaking...
Ya, he defiantly needed some backing plates atleast for those pillow blocks. Strength does look a little weak in a few places but I would say considering its just a project for a kid who isnt necessary going to beat the living crap out of it. Id say its allright.
With a few mods, it could work decently and the plans are cheap.
bransen111
Southern California
Okay, any ideas to make that a little better?
bransen111
Southern California
What exactly are pillow blocks? Lol
This is a pillow block.
Ya backing plates. A strip of metal with matching bolt holes on both sides of the tube. When the bolts are tightened, they may dimple or pull through the tube, or at least a more likely chance they will pull through when the kart is in use.
If the holes are drilled on the seam it will split easily, and even if not still the same thing will happen.
bransen111
Southern California
...Or you could weld on a flat plate & use flange bearings
You can get free plans that are better...
Thanks, any links? I know I can get better quality go kart plans but what I'm really looking for is a super easy and detailed, maybe even dumbed down version because it's my first one and a lot of the stuff I have no idea what it means haha
bransen111
Southern California
Thank you how would I go about getting those spider kart plans? It looks pretty simple haha
