bobakazooboy
I've reached a snag in my build. A year in the making, this kart has been difficult to find parts for so I have substituted or fabricated most everything from scratch. It started as a rusted beat up chassis and I cut and extended the frame 12 inches for adult riders. I took it to bare metal and spray canned it back to red. My problem is where the drive wheel hooks to the sprocket. I have increased the size of wheel in the rear to a 12" tire on a 6" wheel hub. The original set up called for a wheel hub that not only had a skinny profile, but was closer to the frame from its midpoint, and it also had its own built in adapter that hooked on at the lug bolts. I'm needing a way to get a longer set of either bolts or some sort of adapter that will fit the wheel and extend out far enough to reach the sprocket so that it will link up true to the centrifugal clutch assembly. So basically it has to be strong enough to take the brunt of the drive wheel and be longer than the double flanged hub thats on there now. If anyone has any insight or knowledge about how to do such a task will you please email me or comment with some feedback.
Thanks!!
Thanks!!
