It started out as a box stock harbor freight clone engine, but that wasn't enough for my lead foot. I quickly spent all of my teenage money on this project and then lost interest and its sat now for likely almost a year, but its time for its Resurrection. I have since lost/forgotten some of the specs but hopefully with this forum and my patience and commitment to doing things right, we will bring her back to life.
Currently installed:
1:2 ratio rocker
chromolly push rods (bent one)
really big valve ported and milled head (unkown specs)
dual springs (unknown lb) (green?)
lashcaps and keepers
22 mm mikuni (need help with jetting)
stage 3 exhaust
agk .276 lift cam
arc adjustable flywheel and stock length rod
flat top piston stock height
walboro fuel pump
and probably some other minor things that im forgetting.
This engine has a high compression ratio. I have though about possibly 1:3 ratio rockers if theyll fit. I imagine the compression is high enough and that i shouldnt toying with increasing it further.
The main issues i am having with this set up is:
1.) 22mm mikuni carb proper jetting/air/needle settings for this beast. I REALLY WANT SUGGESTIONS HERE.
2. Timing
I figured id start off right and tear it down completely and start fresh. I found it had not enough oil and a bent chromolly push rod, and some wear on some other parts pictured below.
my questions are as follows:
1.) Does the wear on the piston and crank/bearings look acceptable or do they need replacing?
2.) Does anybody have suggestions on possible jetting solutions with the mikuni and this set up? (main jet and the other one)
3.) Do i need tougher pusher rods? im not sure how i bent the chromolly push rod with the engine running under its full potential, will there be more to come once i have it up to 100%?
4.) Does anyone know where to get an intrepid bearing carrier? why am i having such a hard time finding one like mine?
ANY ADVICE/POINTERS/ DISCUSSION WOULD BE VERY HELPFULL!
1:2 ratio rocker
stage 3 exhaust
agk .276 lift cam
walboro fuel pump
2. Timing
