This beast wont run right. Need advice.
tezlem86
It started out as a box stock harbor freight clone engine, but that wasn't enough for my lead foot. I quickly spent all of my teenage money on this project and then lost interest and its sat now for likely almost a year, but its time for its Resurrection. I have since lost/forgotten some of the specs but hopefully with this forum and my patience and commitment to doing things right, we will bring her back to life.
Currently installed:
1:2 ratio rocker
chromolly push rods (bent one)
really big valve ported and milled head (unkown specs)
dual springs (unknown lb) (green?)
lashcaps and keepers
22 mm mikuni (need help with jetting)
stage 3 exhaust
agk .276 lift cam
arc adjustable flywheel and stock length rod
flat top piston stock height
walboro fuel pump
and probably some other minor things that im forgetting.
This engine has a high compression ratio. I have though about possibly 1:3 ratio rockers if theyll fit. I imagine the compression is high enough and that i shouldnt toying with increasing it further.
The main issues i am having with this set up is:
1.) 22mm mikuni carb proper jetting/air/needle settings for this beast. I REALLY WANT SUGGESTIONS HERE.
2. Timing
I figured id start off right and tear it down completely and start fresh. I found it had not enough oil and a bent chromolly push rod, and some wear on some other parts pictured below.
my questions are as follows:
1.) Does the wear on the piston and crank/bearings look acceptable or do they need replacing?
2.) Does anybody have suggestions on possible jetting solutions with the mikuni and this set up? (main jet and the other one)
3.) Do i need tougher pusher rods? im not sure how i bent the chromolly push rod with the engine running under its full potential, will there be more to come once i have it up to 100%?
4.) Does anyone know where to get an intrepid bearing carrier? why am i having such a hard time finding one like mine?
ANY ADVICE/POINTERS/ DISCUSSION WOULD BE VERY HELPFULL!
tezlem86
more pics
:useless:
i found the wear on only one of the keepers from the lash cap interesting.
I'm a little confused about the two heads; the HC head is clean &, obviously, unused & the other head is covered in a thick layer of black carbon with a nice tan coloured sparkplug, which gives the appearance of having run either very hard or for a lot of hours, as do all of the other parts...
The colour of the spark plug indicated your jetting is perfect, maybe a tiny bit lean &, I would guess, your compression ratio is a tad high, as is the ingition timing...
Also, twin threads are a no-no so I have deleted your other identical thread...
tezlem86
I noticed it got moved back over but was unable to delete it myself, so thanks for that! wont happen again.
As for the heads. The head and the block picture is how it looked when i first disassembled it today. The two heads side by side are merely in the same picture together to reference the various size difference between the two. The HC head hasnt been run for quite some time, likely before any modding was completed. And the clean head is the big valve head after i cleaned it up today. I did run this kart quite hard to be honest, so it
As for the heavy carbon build up, the kart never idled properly, engaged the clutch when i didnt want it to, and always ran rich on the low end (puffs smoke) which i suspect is why it looks so carbon coated. Ive done research and believe my pilot jet was either to large or the needle position was too low, or a combination of both. The kart became less bogged as it picked up speed and took off when it the "sweet spot", mid to high range was reasonable but the low end is definitely all wrong, so maybe my main jet isnt too far off. but you are correct, that golden brown does look quite nice. Essentially adjusting timing will adjust where the "sweet spot" is in my RPM range? what makes you beleive its too advanced?
Is there still life left in these parts? or is it better to swap? id like to keep em if i can, but if the experts say its gotta go then id be a fool to ignore. Do you think the push rod was a freak accident or is it time to upgrade to something better?
...yes? Is there an end to that sentence?
Well, for starters...
Ok, you still have a problem with the pilot jet but, that stops working the second the main jet kicks in. Having the timing advanced means that you'll have a great top end but, it won't fire correctly at low end; retard the timing a bit & see what happens...
The thing to remember here is these engines were only designed to rev to 3600rpm; the more you move the "sweet spot" to that point, the worse your low end is gonna be...
IIWM, I'd be replacing them, they appear to have had a hard life. The problem is, if you keep using them, they may ast years or days before catastrophic failure, there's simply no reasonable way to tell & it's better to be safe than sorry...
tezlem86
excellent advice sir.:idea2:
ill get some parts in the mail, i cant wait to do some testing.:wai:
zbuck
Ft. Wayne, IN
:wai:In picture number 7. Looks to be a stock rod with the babbit gone. If it was me, with all that engine work, there would be a alum billet rod with bearings in that engine. Also with the babbit gone on the rod, I would clean up the crankshaft rod journal and mic it for dia against factory specs and wear limits.
tezlem86
it is an arc rod with bearings, blew up the HC rod long ago, decided to never do that again for my pants sake...:oops:
